Tilted wheels? Help
Old Apr 11, 2004 | 02:02 AM
Philly#1 Lex's Avatar
Philly#1 Lex
Default Tilted wheels? Help
I was working on my car today and I happened to notice when I was putiing my wheels back on that all 4 of my wheels were tilted in I anad Look at the back of the car and looked from the back wheels on up and I am positive they are all tilted inwards And in the morning when I am going to work I get this annoying squeak Only when the car is cold though! My question is what Action should I take? I believe the camber is off? Do I need the Daizen Bushing Kit or just get My car realigned. I had it aligned maybe 6 months ago I also started to notice a shaking in the steering wheel again I am so mad. I plan on dropping it 1" with the eibachs and getting 18X8.5 all around next month but I want everything fixed at the same time so I dont get increased tire wear. HELPPPP!
Philly
Old Apr 11, 2004 | 04:31 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
SC's (or at least Soarer twin turbos ) have natural camber, but on any car that I know of, if you take off the wheels (say to work on something) and you put them back on it definitely needs a realignment.
My car has natural camber
But I'm swapping out the rims (for 16" Supra wheels) for an interstate trip in two weeks so I don't wear out my tyres hehe
Jose
Old Apr 11, 2004 | 03:26 PM
PERRYinLA's Avatar
PERRYinLA
Question
Originally posted by Soarer_25GTT
....but on any car that I know of, if you take off the wheels (say to work on something) and you put them back on it definitely needs a realignment......
You're kidding, right?
Old Apr 11, 2004 | 04:07 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
No.
Old Apr 12, 2004 | 07:14 AM
Philly#1 Lex
I never heard of that? So which one of you are right Perry or 2.5GTT So I dont need a camber kit?. And isnt it kind of wierd to need another alignment within 6 months?
Philly
Old Apr 12, 2004 | 07:31 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
Philly,
I really don't know anymore, but I always need a realignment when I take off my wheels because I've got a habit of messing around with my suspension height Maybe you don't, who knows. From what I know, there's quite a bit of camber adjustment available on the Soarer (twin turbo, don't know on the V8's/SC400)... It's weird to need an alignment every 6 months unless your bushes are gone (apparently, that's what I've heard as well).
A quote from the Planet Soarer website... 1/3 of the page down...
Well looking at the old bushes it was clearly apparent they were well and truly stuffed. They were the reason the camber couldn't be adjusted any more...
Hope that helps.
Jose
Old Apr 12, 2004 | 07:37 AM
vipsoarer's Avatar
vipsoarer
unless you have played with the steering rack or the suspension mounts you will not change your alignment. if the tires tilt in at the top that is camber and most cars run with a little bit of camber...when you lower your car it changes the geometry of the suspension and creates camber also. if the fronts of the tires tilt in thats toe and that is something that will be fixed with an alignment. if you have excessive camber you will need a camber kit or some sort of kit to adjust it since it cannot be adjusted with the stock setup. shaking at 60 mph sounds like the wheels need balanced but if it only happens at that speed and only that speed i would take it to a shop to have it checked out for bad tires or worn suspension parts. good luck and i hope this helps.
Old Apr 12, 2004 | 07:48 AM
Philly#1 Lex
My car isnt lowered and I just went outside to look at it and my front driver side wheel is cambered more than the pass. And both of the rears are as well. yesterday I hade the driver front off becauser I was wiring a Amp and needed to get into the wheel well area. Man I am starting to get ticked!
Philly
Old Apr 12, 2004 | 12:26 PM
vipsoarer's Avatar
vipsoarer
philly it sounds to me like you might need some new springs or shocks then. you say the driver side sags more than the passenger? that would sound about right since the drivers side is used the most and would have more weight on it to sag.check to see if the car sits lop-sided that can tell if you have sagging parts. if you are planning of replacing the shocks and springs soon i say try that as it would remedy sagging springs and busted shocks. good luck
kuyaariel
NX - 1st Gen (2015-2021)
Feb 13, 2017 01:44 PM
bashigs300
May 15, 2012 09:45 AM
kim0217
Suspension and Brakes
Apr 13, 2012 10:19 PM
randee973
Feb 9, 2012 07:23 PM
Minderaser
19
Oct 15, 2007 01:10 PM
