front brakes in the back?? is it possible?
ok, i have a feeling i'm about to get flamed.....
here goes. i want to go supra tt brakes in the front, and stock sc300 front brakes in the rear... is this possible? if so, how?
let the flaming begin
Why not just use the Supra brakes all the way around?................to each his own, I guess. Yes, it is definatly possible........just make a braket to bolt between the caliper and the the mounting flange. This is the same way most Big brake upgrades mount on the front!
Jimmy
Jimmy
You will loose your e-brake. The rear stock rotors on both the supra and the SC have a brake drum on the inside which is what the e-brake uses to hold the car in place. You are better off getting supra's all around.
MrJohnTan,
I think he just wanted to mount the calipers on the back, and keep the rear rotors in place? I agree though, still just go with the Supra upgrade all the way around, prolly cheaper in the long run?
Jimmy
Jimmy
maybe? but yeah, he's better off going w/ the supras or even leaving the stock SC300. IMO its not worth swapping out the rears if you only have the front set of supra brakes since 80% of the braking is done by the fronts.
even if possible, wouldnt that change your brake balance?? check this link I found for that.. http://www.stoptech.com/whitepapers/...tter120601.htm
Comparison TT rotors to SC300
Anybody have the specs of the size of the SC300 vs Supra TT brake rotors? The TT has a rep as offering some of the best oem brakes on a car. What makes this so?
http://planetsoarer.com/suprabrakesI...akeUpgrade.htm I believe you might be able to find some of that info there
