Replacing Heated seat module control
So I am thinking about replacing the heated seat control switch on my 2010 HS250. The Passenger seat work fine, the driver seat power button used to light up last winter on certain spots on the 0-3 number dial which leads me to believe there is a problem with the consistency of the dial button and not the actual heated seat. Last Winter both seats heated up just fine.
My question is, has anyone replaced this control switch before and which part of the console do I remove 1st to get to the switch?
Thanks
Thanks
Does it cool? Did you check the fuse, in case they have separate fuses.
I think it may pry up, but you should have the trim tools to protect your finish. Harbor Freight sells them. Look at this to see if it helps
http://www.lexuspartsnow.com/parts-l...tml?PNC=58818A
This is what it looks like however, in my model the seats do not cool down, heat is the only option. And if it was a fuse problem would there be a fuse for each seat because again my passenger seats hear works fine. Where is the fuse box located ?
All you ever wanted to know about your seat heaters, and then some.
Keep us posted on what you find out.
Seat Heater Control.pdf
Seat Heater Switch.pdf
Seat Heater System.pdf
heated seat update
Awesome info! Thank you.
update : so my driver side heat started working yesterday out of nowhere, but the power light was very dim & after about five minutes I started smelling something burning. I attempted to turn the dial to the off switch and it wouldn't shut off so I had to turn the car off and then turn it back on while it was in the off position. This tells me it's not a fuse issue and it must be with the actual switch. My game plan is to buy a used switch and try replacing it. Hopefully I will get to this in the next three or four weeks. After that I will be sure to update
Attachment 396423
Attachment 396424
Attachment 396425
Attachment 396423
Attachment 396424
Attachment 396425
Removing heated seat switch/module
Update:
I could not find anything on removing console parts in the Lexus hs250. So I made a video of how easy it is to pry it off.
you may not be able to see the oil-like substance leaking from the driver side switch once I remove the module. It's apparent that some kind of burning/melting has happened. I will buy a used switch to replace it at a low cost.
here is the youtube link: https://youtu.be/XKYEdFTV78E
Update:
Here's the console removal for next time.
Front Console Box.pdf
Nice video by the way. And if there is a next time, maybe get yourself those plastic interior panel pry tools because the first scratch from using a metal pry tool gives you a sick feeling in your stomach. Don't ask me how I know !!!
Fixed!
https://youtu.be/oREsZgEeXeY
bought replacement on ebay for $80 and switched out in under 1 minute. Seats are back to working condition.
the dealership sells this part brand new at $400ea! Installation is another $230! I was quoted at the dealership for this to be fixed at $630! I saved myself $550!
Great job figuring this out and doing it yourself!
Mine wasn't working so I took the switch all apart and cleaned the contacts inside. Apparently the previous owner spilled coffee into the switch. Been working perfectly ever since.
