Cool "hidden" features about the GS that are not very known
Old Jul 22, 2007 | 02:47 PM
  #316
bandgap112's Avatar
bandgap112
Originally Posted by jesod
You don't have 1 and 6 buttons for radio presets? If it's nav you have to follow the procedures mentioned in the posts above. If you don't have nav. push the 1 and the 6 on the radio presets and push CD 4 times release everything once you see P190 and then hold the AM until Audio comes up, then adjust according to suggestions in previous posts.
Can someone confirm whether this audio mod works on my '02 GS430 with Nav, ML? I can get to the Japanese diagnostic screen by pressing down the CLIMATE+AUDIO while toggle the parking light 3,4 times. What are the next steps I need to do to get to the audio menu (if possible)?
Does anyone know if this audio mod. is applicable to my wife's '00 RX300? I think that car has the Pioneer stereo.
Thanks,
bandgap
Old Aug 15, 2007 | 09:08 AM
  #317
Donuts's Avatar
Donuts
Amazing post !.. will try most of the Tricks.. soon ! but i lost my remot.. too sad
Old Aug 22, 2007 | 06:37 AM
  #318
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
I tried the audio mod on my '01 GS430 and it didnt work, i could get no farther than the P190 screen, but now I have a small problem, every once in a while my radio screen spazes out and displays all kinds of weird characters ... anyone know what that could be?
Old Aug 22, 2007 | 07:21 AM
  #319
DJ TANTRA's Avatar
DJ TANTRA
I was trying the wiper thing..to put it in summer mode!
didnt work!!
I have a 2001 GS430..anyone try it?
when i first tried it..I noticed my bolt was loose on the base...tightened it..but it doesnt shift upward...or downward!! :-(
Also since the nut was loose..and my wiper was a little protruding..i chipped the top part of my hood..barely noticeable --BUT very painfullll
Old Aug 22, 2007 | 08:05 AM
  #320
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
Yea i went ahead and did the wiper thing, and it was really easy actually ... When i first tried doing it myself it was hard and i couldnt push it down ... so i got my friend to help me out, i pushed down on the passenger side while she pushed down on the driver side, and it went down effortlessly ... try it out guys
Old Aug 29, 2007 | 04:00 PM
  #321
NBart's Avatar
NBart
Originally Posted by DaveGS4
Good post Drew!
11) There are two 'stops' for windshield wipers on the 2nd gen GS, a winter / ice setting and a regular lower setting. If your wipers on on the winter setting they sit way up high on the window and don't tuck behind the cowl. Just push them down hard and they'll 'pop' past the winter stop into the normal one. Looks much better.
12) If you leave your gascap loose, you will get a check engine light after a bit of driving (this is on all newer Lexus). Put the cap back on tight and it should reset after a while. I disconnect the positive ground on the battery for about 5 minutes to do it right away.
Adding one more to the list. You can hold down the recirculate and vent button for 3 seconds and you will be able to adjust the smog sensor that automatically switches the airflow back and forth between themselves. A/C has to be in the automatic position for recirculate and vent mode for this to work properly.
Old Aug 30, 2007 | 06:14 AM
  #322
av8or4fun's Avatar
av8or4fun
9th Gear
look at #7 on the original list on page 1.
Old Aug 30, 2007 | 07:46 AM
  #323
NBart's Avatar
NBart
Must have seen that and blown right past it. I thought is was a neat trick I found one day sitting in traffic pissed that the temp outside was 103.
Old Sep 14, 2007 | 12:46 PM
  #324
AC99GS400's Avatar
AC99GS400
About the valet parking... wouldn't they have your key anyways? So they can unlock your trunk anyways...
Old Sep 14, 2007 | 01:18 PM
  #325
Benjamin T's Avatar
Benjamin T
i thought that the valet key could not open the trunk and glovebox?
Old Sep 14, 2007 | 09:34 PM
  #326
Remil12's Avatar
Remil12
for the windshield mod? could the wipers be put back into the winter setting as easy as pushing them down for the summer.
Old Sep 16, 2007 | 10:34 AM
  #327
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
yea just pull them up, the same way you put them down ...
Old Sep 27, 2007 | 11:21 PM
  #328
marshun's Avatar
marshun
i went through the whole thread. im guessing the stereo mod doesnt work with the nakamichi stereo?
Old Sep 30, 2007 | 06:30 PM
  #329
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
correct...
Old Oct 1, 2007 | 11:42 PM
  #330
shawn38's Avatar
shawn38
Default Two more
Adding one more. If your trying to get your freak and you dont want your running lights on just depress the emergency brake when you crank the car. Running lights will not come on until you release the emergancy brake. If your car is off and you need to push a button in the drop box just open the driver door. The buttons light up everytime you open the door even when the car is off.
