VSC light after tein cs coilover
Old Feb 26, 2009 | 01:49 PM
lilsharky's Avatar
lilsharky
Default VSC light after tein cs coilover
I went to the shop yesterday to install my tein cs, after everything was done i went into the car and my vsc abs and vsc off lights were on. Question is, is it possible the shop have pulled on it and torn the wire or is it just some coincidence. On the other hand I'm kinda confused on how to lower the height any help with pics please thank.
Old Feb 26, 2009 | 02:28 PM
GSteg's Avatar
GSteg
They most likely pulled on it. When they put back the coilovers, they can't just tie the wires anywhere on the spring they like. They need to lower the car and gauge where the wires should be, then tie it up. This is a common mistake by most mechanics.
Old Feb 26, 2009 | 08:31 PM
lilsharky's Avatar
lilsharky
Angry
well they denied that it was caused by them and when i came back i found a new scratch. hopefully i can use jeff's diy and fix the problem. would anyone know where the abs cable is located and how it looks like. thank a lot
Old Feb 26, 2009 | 08:33 PM
GSteg's Avatar
GSteg
The cable should be attached to your shock body. It'll be obvious.
Raise hell with the shop. Turn your steering wheel until your your cable is at tension. Then show the mess they made.
Old Feb 26, 2009 | 09:13 PM
lilsharky's Avatar
lilsharky
I am never ever going back to that shop again they might give me another scratch plus it took them 8 hrs to install the coilover when i was there right when they opened and waited another 4 hrs for them to figure out where was damaged. i think i know what wire you're talking about(one clipped on with the shock?) but it is as hard as a tube so now i dont know how to see where it will be disconnected at.
Old Feb 26, 2009 | 09:14 PM
GSteg's Avatar
GSteg
The internal wiring has been ripped. The outer rubber jacket is able to stretch. It's the inside wires that can't be, and they're fairly small too.
Old Feb 26, 2009 | 10:09 PM
PHML's Avatar
PHML
Master Thread Closer!!
Another possible reason for the lights is if there is not enough slack on the ABS hose (depending on where you mount it) when turning your wheel left or right...that will definitely set it off.
Old Feb 26, 2009 | 10:36 PM
lilsharky's Avatar
lilsharky
To think of it, i think the lights turned on right when i turned the steering wheel to the right and heard some weird noise. thought it was just the shocks breaking in. ill check tmrw morning again. thanks a lot
Old Apr 10, 2009 | 03:14 AM
mikesblkgs's Avatar
mikesblkgs
i have the same problem, is this a serious issue? how much would it be to get it replaced?
Old Apr 10, 2009 | 12:03 PM
sakataj's Avatar
sakataj
almost free....
heres a DIY...
http://www.projectgs.com/DIY/SuspBrake/ABSVSC/index.htm
Old Aug 19, 2009 | 12:15 AM
TomLee's Avatar
TomLee
I just ran into this problem today. I hate dash lights!
Old Aug 19, 2009 | 09:10 AM
vwynn's Avatar
vwynn
8 hours to install coilovers?? fail lol..
frankiejay
Sep 12, 2018 04:35 AM
SmthgWickd
Jul 5, 2013 10:30 AM
Automan
Suspension and Brakes
Apr 8, 2010 10:43 PM
carmcanc
Sep 28, 2006 09:17 AM
tommyGS3
Jan 10, 2006 09:10 PM
