Quote:
I looked everywhere online, there are no Upper Ball Joints that is/are sold separately.Originally Posted by Enigmatic
I replaced the lower ball joints and the upper ball joints, which is essentially replacing the upper control arm as well since they are one part. Further, I replaced my right wheel bearing as it was deemed bad upon inspection.
Quote:
Here is a 5% discount code for rockauto.. Originally Posted by GokuSSJ3
Purchase them from Rock Auto!! Instant savings.
B8565626D56E
Valid til 5/13/12
Just paste it in the 'how did you hear about us' box.
Quote:
B8565626D56E
Valid til 5/13/12
Dude everywhere I looked they only show the whole arm assembly. Not ball joint.Originally Posted by 99 GS3
Here is a 5% discount code for rockauto.. B8565626D56E
Valid til 5/13/12
Quote:
That's what he said, the upper ball joint is part of the upper control arm, so you need to get the whole arm:Originally Posted by GS714
wow,, i just hit 96k and my right side is creaking pretty loud..im calling my mechanic in the morning..thank you cl for the heads up..this takes major priority over rims...
Wow thank god everyone is alright I noticed on the lift the other day on the bottom of mine there was a really bad torn boot (balljoints)? I'm taking mine to the mechanic tomorrow.. Especially those of you who got children in the car, god forbid, this boils my blood for that reason...
Changed my front LBJ's the other day. 107,000 miles and they were a little leaky and pretty dang worn. Didn't look like they were going to snap any time soon, but they definitely were due. My tie rod ends are also pretty shot. I wish I thought to replace those at the same time. Luckily, I got the liftetime alignment at Firestone so I can replace them in the near future and get it re-set for free
If your 2GS has over 100k miles and original LBJ's...replace those suckers.
Bump^^
I just got my car back from the mechanic I have 121k on my gs400, he said him and 2 other guys tried to budge my balljoints and they couldnt get them to budge? Is this normal? That's crazy, Im getting them replaced anyway in a few weeks or sooner, I'm not taking any chances..
replace the inner Tie roads at the same time. there is a DIY on here for that alsoOriginally Posted by mk2tmr2
Quote:
there should be a DIY somewhere...try searching.
special tools: you'll need a 2 or 3 claw SST puller. free to rent at autozone (you pay like 30 bucks up front but you get it back once you return it).
I'd do it for you for Outback Steakhouse if you were in Chicago
...not sure why but have a craving for Outback now lol.
I'm from Chicago. Would u help me to do the LBJ replacement? I will pay u for ur time Coco-bunOriginally Posted by Coco-bun
dealership usually has them for under $100/side since it's a common thing for GSs.there should be a DIY somewhere...try searching.
....not sure why but have a craving for Outback now lol.
Damm! My LBJ's need replacing too. New ones along with bc coilovers coming in soon. Any reliable mechanics in south houston tx area?? Not trying to spend an arm and a leg tho.
Damn i havent seen this but i think i was close to getting to this. I got my mechanic to search for some better ball jonts than toyotas and he got me some 555 balljoints from japan. . . $450 a pair it dint matter the price just needed something better than oem and also got a set of daizen bushings installed. Perfect and very responsive.
ouch thats some expensive pair of ball joints
my 2001 GS300 only has 68k miles on it on stock suspension
not lowered or anything
and my mechanic found some play with the LBJ so we got it swapped out to new ones
$300 parts + labor for a cheap mechanic while he was doing my brakes (EBC woohoo!
cant believe how fast these LBJs go!
id hate to change it every 70k!
here is the whole control arm and upper ball joint
you can use CL10 for 10% off
right:
http://autoshepherd.com/beck-arnley-...-assembly.html
left:
Here is the LBJ for 2GS
Left:
http://autoshepherd.com/beck-arnley-...all-joint.html
Right:
)cant believe how fast these LBJs go!
right:
left:
Left:
Right:
