LS400 VVTi soleniod- P1349 and P1346
Old 01-03-18, 12:12 PM
DarrenUK
DarrenUK's Avatar
Default LS400 VVTi soleniod- P1349 and P1346
Hi All, first post here.
Car has been running very rough, read codes and got P1349 and P1346
Followed advice from other posts on here, cleaned the oil control valves but the left hand side ( bank 1 ) valve still sticks.
The codes on the parts are 15340-50010 0050 on the faulty one
and 15330-50010 0040 on the working one
Can anyone recommend a parts supplier/ dealer who would be able to supply them and who ships the the UK?
also, is there any equivalent parts i could use, from a newer LS or GS for example?
Thanks in advance,
Darren
Old 01-03-18, 12:40 PM
OldLs400
OldLs400's Avatar
I think Rock Auto ships to the UK.
Old 01-03-18, 06:07 PM
UNCNOR
UNCNOR's Avatar
Thanks in advance,
Darren
Try amayama.com
Scraape (01-04-18)
Old 01-04-18, 06:45 AM
dveneman
dveneman's Avatar
Check your PM messages Darren.
Old 12-10-18, 02:29 PM
mohammed06
mohammed06's Avatar
Thanks in advance,
Darren
hello , I have a similar problem with my LS400 year2000. I didn't find anyone can fix it, last shop told me that you should sell it. Did you solve your car's problem?
Old 12-10-18, 05:02 PM
RA40
RA40's Avatar
Miles on car, was there recent service performed?
The OCV is a common error and replacement when these two error codes come up.
The other is a timing belt that is off a tooth or so. If this error came up after a timing belt service, have it towed back to the shop for them to fix.
Old 12-10-18, 05:15 PM
Yamae
Yamae's Avatar
Have you checked OCV filters installed in camshaft caps?
If there aren't any mechanical problems, the next step will be to check OCV drive signals coming from the ECU.
Old 12-10-18, 06:33 PM
mohammed06
mohammed06's Avatar
Hello thanks for your quick response
i had a probelm with the alternator i didnt replace it immediately. I keep jumping the car before i use until i get this issue. After that i bought a denso alternater from walmart app and I installed it. The battery light turned off but this issue still exist. I replaced the spark plugs but stll issue the same.
milage is 199000
the sticker on the engine said the timing belt was replaced on 92000
i dont know what I should do. I really like this car and i dont want to loose it. I am the second owner.i bought it on 2016 and i never got any issue with it
Old 12-10-18, 06:39 PM
mohammed06
mohammed06's Avatar
no sir, i never dealed with electirical parts and the shops told you need to pay alot of money to find the problem witch is weird
Old 12-11-18, 10:36 AM
RA40
RA40's Avatar
Use another shop, sounds like they are passing you off because they don't have the familiarity to work with Toyota/Lexus.
These threads for some additional reference reading:
https://www.clublexus.com/forums/ls-...vt-filter.html
https://www.clublexus.com/forums/ls-...a-and-ocv.html
https://www.clublexus.com/forums/ls-...er-change.html
Old 12-11-18, 11:39 AM
mohammed06
mohammed06's Avatar
thanks alot, i will go over them ans try to fix it
Old 12-12-18, 09:19 AM
sha4000
sha4000's Avatar
You can change the OCV but to get to the filter is a lil more involved. When u get home tonight I'll try to post up some pics if Billy doesn't chime in.
Old 12-12-18, 10:00 AM
mohammed06
mohammed06's Avatar
Yes please😭
Old 12-16-18, 05:09 PM
mohammed06
mohammed06's Avatar
After long troubleshooting we found that all or the cylinders that located in the left side are not working, means the car has only four workings cylinders out of 8
ta1972
09-19-12 12:03 AM
corban
07-29-12 12:31 AM
lewisj
01-16-11 07:11 PM
Mr.Euro
Lexus Vehicles Classifieds
05-08-10 04:24 PM
lisach
07-30-09 11:26 AM
Quick Reply: LS400 VVTi soleniod- P1349 and P1346
