VSC light
If it does not go away in a day or two with a few start/stop cycles (sometimes after heay rain mine goes on), get it checked/fixed. As per above, mght no have anythiong to do wih VSC depeding on what else is lit up.
https://www.google.com/search?q=lexu...t=gws-wiz-serp
Also check the "VSC Light Puzzle" thread the appears below this one, very helpful.
There is also a thread below titled "How to reset the VSC light". I'm iffy on the 'just reset it' solution. Yes, computers can malfunction, but generally if the car turned the light on, there is a reason. I do ignore TPS sensors though, altitude and temperature can set those off, so I do reset that.
You need to figure what is makimg the car throw a code.
