2019 GX460 100k miles needs trans, diff, and trf case service
My wife's 2019 GX460 has 100,000 miles and no leaks or problems.
We have never serviced the transmission, front and rear differentials, or transfer case.
Dealer and independent shop both say flush the transmission, so I went to a highly rated transmission shop and they said we need to remove the pan, change the filter, and install new gasket with just drain and fill.
I am an amateur at this so based upon what I have read online the Transmission shop seems best to trust with what to do.
Your advice?
Thanks!
If I were in your shoes, I would perform the following to ensure another 100k of trouble-free miles:
Transmission Service
Skip the flush. Have the shop remove the transmission fluid plate, replace the internal filter/strainer and O-ring, and install a new pan gasket.
Required Parts: Strainer (35330-60070), O-Ring (90301-31014), and Gasket (35168-60010).
Fluid: Only use Toyota Genuine ATF WS (00289-ATFWS), if you want to use amsoil its up to you, in most cases Toyota OEM WS works great.
Differentials & Transfer Case
In case these have never been touched, the fluid is likely well past its prime.
Front & Rear Differentials: Drain and fill with GL-5 gear oil (SAE 75W-85).
Transfer Case: Drain and fill with 70W/75W GL-4 fluid.
Crucial Step: Replace all 6 crush washers (for both fill and drain plugs on all three units) to prevent leaks.
Check the rear differential breather in case it's stuck, part number 90930-03031
Driveline Maintenance
This is the most overlooked service on the GX460. If you haven't done so yet, grease the drive shaft
Apply fresh chassis grease to the 4 spider joints and the 2 slip slide yokes. This prevents the common "thump" felt when coming to a stop.
Hope it helps!
The other two, can be done as home if necessary, if you dont mind the mess. turkey baster ps fluid, drop the coolant in the rad, and while not perfect, better then a lot of GXers.
Ps fluid is any dexron 3 if you dont mind the red staining.
Coolant, use toyota sllc.
Total cost was $1,200 including the driveshaft and joints lube.
Said my transmission and transfer case and differential fluids were ok and no particles.
Good to know after 100,000 miles.
I am very amateur so let me know your thoughts and costs?
Our 2019 GX460 is running great and the dealer does oil changes but I do cabin and engine air filters.
Just understand there's a lot of "wallet flush" type services that are pushed.
Hope it helps!
good advice..
to add to this:
drain and refill the coolant (Use toyota long life coolant). easy job to do...You can just do it from radiator. about a gallon. drain /refill twice, each time bring to operating temp and max heat to burp air.
Replace the radiator cap with new one.
power steering flush (Use Idemitsu PSF)
and brake fluid flush. ( I like ATE 200)
for transmission, a drain and fill without removing the pan is ok as well....
I purchased the Radiator fluid and cap from the Toyota dealer and price was 50% of Lexus parts.
Is this a good fluid for the power steering fluid change? --> Valvoline MaxLife Multi-Vehicle ATF Full Synthetic Automatic Transmission Fluid 1 Gallon
