NX - 2nd Gen (2022-current)
450H+ Steamy windows when using remote start
Old Nov 26, 2025 | 02:19 PM
marcel488's Avatar
marcel488
Default 450H+ Steamy windows when using remote start
Hey, just wondering if any one else gets really steamy windows when using the app to start your car when it’s below 5 degrees Celsius and raining, or the day after it rains. I assume it’s specific to the NX with the heat pump system.
I've had this problem since the car was new. I noticed today the car puts the climate system in recirculate automatically, then turns its off once you open the doors. Then it’ll start defogging the glass.
any suggestions? There’s no setting in the app to turn off recirculate.
Old Nov 26, 2025 | 03:36 PM
redgs400's Avatar
redgs400
I haven't tried to resolve this issue, but I have also seen it on our 2022 Prius Prime when I use Remote Connect to pre-heat the vehicle before leaving work. Same situation: the heat pump runs to heat the interior but apparently the settings used causes the windows to hopelessly fog up
Old Nov 26, 2025 | 06:24 PM
Castrum's Avatar
Castrum
Veteran: Canadian Forces
Default Use Climate Instead Of Remote Start
Try using the Climate option in the app instead of remote start to precondition your car. Also make sure that defrost is selected in default climate settings and also the scheduled climate conditions.
Old Nov 27, 2025 | 08:08 AM
lsft's Avatar
lsft
Does the gas engine turn on if you have the defrost on?
Old Nov 27, 2025 | 08:10 AM
Castrum's Avatar
Castrum
The gas engine does not start with Lexus NX450h+ plugged in and running Climate mode with the Lexus app.
Old Nov 27, 2025 | 10:31 AM
TechNut's Avatar
TechNut
Veteran: Navy
I believe this is a common problem with Toyota/Lexus design. For some reason, the designers heavily favor recirc, which can lead to moisture buildup in the cabin. It has also been a common refrain in the ES and RX subforum. The more frequent complaint is a buildup of a moldy odor, to the point some owners switch to fresh air a few minutes before shutting the car off - especially in the summer and in higher humidity regions. This seems like a similar design challenge and I think Castrum has some good ideas. I wish I had something encouraging (useful) to offer, but I don’t. Fortunately, I live in a very arid climate and rarely experience this particular challenge.
Old Dec 18, 2025 | 07:20 PM
jelee's Avatar
jelee
This year I noticed some changes. When remote start from the app is engaged, the front defroster turns off as
soon as you open the door. Also I have noticed back passenger windows foggy on the passenger side. So, recently, I set the temp to highest heat level to see if that helps. When I engage front defrost, hybrid mode engages. I have not noticed the engine running when my car is plugged in and remote start is engaged. I only notice it when it is not plugged in that hybrid mode engages.
Old Dec 19, 2025 | 02:56 AM
spbonzo's Avatar
spbonzo
Another unwanted consequence of the steamy NX windows is that over time the inside of the windscreen becomes really grubby. I've never had to continually clean the inside of the windscreen as often as I've had to in the NX.
The only solution appears to be to use the AC option a lot more.
Old Dec 19, 2025 | 06:03 AM
Droid13's Avatar
Droid13
I've not had really any trouble with inside windows. I shut off automatic recirc mode in vehicle settings and leave the car on fresh air setting 99.9% of the time. The only time I use recirc is if I'm stuck behind a diesel or oil burner (or the rare carbureted car).
Old Dec 21, 2025 | 09:31 AM
TheCDN's Avatar
TheCDN
Front windshield goes foggy with newer cars as all the plastic in the dash material 'off gases' their oils. The residue collects on the windshield rather quickly and I usually need to clean it 2-3 times a year in the first 3 years then it drops off and not as much, my '22 I cleaned just once this year in '25 and now in December it's doing ok. I'll probably have to clean in March maybe, although I only drive around 15kms a year presently.
Please everyone be very careful not to scratch your very poorly produced soft touch dash surface!! It scratches even with a soft cloth and a little elbow grease!
brenpmcl96
GX - 2nd Gen (2010-2023)
Nov 15, 2025 10:56 AM
baneling
Jan 25, 2024 05:35 AM
HontoKuro
Dec 17, 2021 03:20 PM
mcfancy
RX - 4th Gen (2016-2022)
Sep 7, 2016 07:42 AM
cmclien
RX - 3rd Gen (2010-2015)
Mar 24, 2014 10:35 AM
