LS400 owners post your wheel setup
Old Oct 12, 2017 | 10:10 AM
  #2386
EthanS's Avatar
EthanS
That's rad! Was it originally a white/silver two-tone? Either way I like how you left the lower grill in the front bumper accented, looks like the original silver.
Are your corner lights removed in an attempt to get rid of the pesky amber blinker covers inside? I recently did that job on my 99, not as easy as most other cars.
Old Oct 13, 2017 | 08:24 AM
  #2387
EENCIZO's Avatar
EENCIZO
Thumbs up
Originally Posted by slowucf20
1998 lexus ls 400
stance coilovers not maxed put yet fronts are hitting and need stiffer springs
1 inch spacers in front
​​​​19 inch weds bazarias unknown specs rebuilding soon
are you in Fresno? I think I saw this car before.
Old Oct 15, 2017 | 11:32 PM
  #2388
Sc0pe's Avatar
Sc0pe
Originally Posted by danzafar
I need to make this happen...without dying on the highway!
Help.
A bit green here, so excuse the 'common-knowledge' questions. Got this baby imported from Japan (more on that a separate introductory post), and also in Japan I found a good deal on the SC430 wheels you see attached to the car.
The auctioneers in Japan had to use two spacers on each of the front wheels to clear the callipers (not sure which length), but from what I see there is very little thread for bolts to hold on to. The steering wheel vibrates at 90kms (only), and I initially thought the wheels needed balancing as there’s no guarantee they were balanced when they were slapped on.
My local shop has declared these wheels completely unsafe for road use because of the lug situation and out of fear of one of them snapping while I’m driving. I’m bringing the car to a different shop that specializes in wheels to get hub-centric spacers with longer lugs AND to balance the wheels, both of which I’m hoping fix the problem. Currently I am not exceeding 80km/h until the car is looked at.
My concerns are:
I’ve seen many UCF20s with these 430 wheels, perhaps some of you have this setup too. What kind of precautions should I take to have this going? If these wheels are that incompatible with the cars, how are there so many in the wild? Any of you with a 20 running spacers on the ear wheels?
Thanks.
If you're just trying to get the fronts to clear stock brakes, I would recommend ordering some 55mm extended wheel studs (OEM studs are 40mm for reference) and some 15mm hubcentric wheel spacers.
Old Nov 13, 2017 | 09:28 AM
  #2389
ATLs400's Avatar
ATLs400
Question
aight ive been through about 100 pages of this thread and i cant get a good idea of the setup im looking for: i have a 98 ls400 bone stock. i wanna drop it an inch maybe up to 2 inches but i want to maintain as much of the awesome ride as possible. not looking to do any crazy tracking(yet at least) but would always like to improve handling where i can. plus i live by the dragon and would like to cruise it up there every once and a while . not looking to do any insane camber or anything, going for function over form. im interested in coil overs, dont really have the money for bags. ive been looking into BC and megan coil overs. they are a little pricey but if they are the best comfort and performance for the money im not against dishing out a few extra bucks. are there any other good kits i should look into? also as far as megan and BC goes, whats the best kits for comfort street/weekend warrior builds? will also mention that i daily the beast hence why im looking to keep it comfortable. note:i drove an s2000 before this car so im no new comer to stiffer suspensions.
thanks guys
Old Nov 13, 2017 | 12:25 PM
  #2390
helladrew's Avatar
helladrew
Old Nov 13, 2017 | 12:35 PM
  #2391
driftsucky's Avatar
driftsucky
Those look very R35ish.
Old Nov 15, 2017 | 05:39 PM
  #2392
mikuza's Avatar
mikuza
Hey guys,
First post. Got my friends at AUTOCouture fitting the fronts now that I had fuca's arrive. Wheels are Rotiform ROC's, no center caps cause I lost one and want them all first lol
Old Nov 16, 2017 | 06:15 PM
  #2393
driftsucky's Avatar
driftsucky
Your first post trumps my last 87. Car looks minty fresh.
Old Nov 17, 2017 | 10:09 AM
  #2394
mikuza's Avatar
mikuza
lol thanks man, will post more pics when I pick it up later today
Old Dec 8, 2017 | 04:19 PM
  #2395
scrapinls's Avatar
scrapinls
Default Here’s babe on 18s
Old Dec 12, 2017 | 11:17 AM
  #2396
Kaspars's Avatar
Kaspars
Hi!
I'm First time poster! I desperatley need your help.
I'm looking through this thread but still can't figure it out. Because half of the time looking at number - offset, spacers etc., fittement seems mild, but then you look at pictures and the rim is poking outside the fender. But then on the next page I see someone running even bigger wheels with more agrresive offset and he is tucking them behind the fender. And Im like ???
I would like to run 19x9.5 et35 all around with realitvley meaty tire of 235/40. Im planing to drop the front atleast 40mm and the rear 30mm, (most likley i will end up with 50mm and 40mm) And maybe put 15mm spacers on the rear, as long as I dont have to touch rear fender lip too much as it quite finicky.
Will this setup work? I assume that I would have roll the lip in the front if I wanted no rub anywhere in the wheel travel. But Rear should be ok? Or I would I have to atleast half roll the lip?
As plan B, I'm looking at staggered setup, 19x8.5 et35 235/40 and 19x9.5 et35 245/40
I would really appreciate your help. Thanks.
Old Dec 14, 2017 | 10:01 AM
  #2397
Stanislav's Avatar
Stanislav
Previous setup (bought with these):
17x7,5 ET38 235/50 Michelin summer tires.
In my opionion they are ugly, offset also isn't nice.
Exsiting setup:
Audi A8 Monoblock wheels with adapters to 5x112.
18 x 7,5 235/45 Winter Sunfull tires.
Front: ET40 - 20mm spacer = ET20
Rear: ET40 - 25mm spacer = ET15
Front is rubbing sometimes on big deep holes. I think it's inner fenders holders, will try to cut them off.
Rear fits perfectly, when car full lowered and wheel goes inside - it's about 1-2mm from fender, nothing rubbing.
Rims looks more like 8 inch wide, not 7,5".
Old Jan 3, 2018 | 10:37 AM
  #2398
FortuneLS's Avatar
FortuneLS
Originally Posted by mikuza
Hey guys,
what wheel specs and suspension mods do you have? looks SIIIIIIIIIIIIIC!
Old Jan 6, 2018 | 06:49 PM
  #2399
Mediclexus's Avatar
Mediclexus
Default 5th anniversary project. 18x9.5 rear 18x8.5 front. Coilovers
Old Jan 6, 2018 | 06:52 PM
  #2400
Mediclexus's Avatar
Mediclexus
ESR 18x9.5 rear with cooper 255/40/18
18x8.5 front with cooper 235/40/18
drilled and slotted rotors with ceramic pads all the way around.
Lowered with truhart Coilovers.
