Love those wheels! Do you know if they are available in either the stock 16 or a 17 inch size so I'd basically have the same look of my car but with those beautiful wheels?
The wheels above are factory LS460 wheels, and only come in 18" sizes (& 7.5" wide?). Also the lug nut seats are mag/flat type, and wider than most. I believe that only OEM LS460 or LX570 lug nuts sit properly in the seats. Someone, PLEASE correct me if im wrong.
This also means that not only does the PCD change, but so does the lug diameter, m12 to m14?
Putting 460 wheels on a 400 is not rocket science, but its also not a super straight-forward swap. I was in the middle of getting that swap dialed in myself, but stopped when I found a good deal on a set of aftermarket wheels that fit even better.
I have a 97, and my friend has some 18x9.5 +35 for cheap I want to pick up. The fronts didn't fit over the brakes, so what size spacer would I need to get clear of the brakes?
Any help would be appreciated.
18x9.5 is aggressive already and you may need run negative camber with stretched tires. The only way to determine that is if you have the X factor of your brakes, make a template of your brakes and measure it from your back pad to your spokes.
it all depends on the spoke/pad design. offset has nothing to do with caliper clearance, but I admit we can guestimate if you will need spacers or not. yes you may need as small as a 5mm spacer to clear.
I have 19x10 +25 wheels up front on my 97 on stock (albeit trimmed, no pull) fenders, barely a stretched tire at 245/35, and I ride tucking tire!
12mm spacer will clear just about every aftermarket wheel
Weather was finally clear enough to get my coilovers and wheels on. I still have LOTS of room to drop in the rear without fear of rubbing, but it would be pushing it a bit.
Wheels: Avid.1 AV-06 18x8.5 +35 18x9.5 +38
Tires: BFGoodrich G-Force Sport Comp 2 225/45/18 235/45/18
Suspension: Final Konnexion Limited
Body work: Absolutely NONE
Looks good at that height. Don't for get to show that Corolla hiding in the background some love.
