Remote want unlock door
After timing belt service my fob will not unlock doors. If I hold button the windows do lower. Is there some type of key leading needed after battery disconnect?
thanks
Brian
thanks
Brian
The answer is no. The fact that you could low the window means there is some kind of communication have been made. Try to hold the fob close to the door, and avoid the sun ray or heat. SC keys sometimes do not work in heat.
Most likely a quick reprogramming of your remotes will solve the problem. Keep in mind there is the programming of your key to start your car (not what you want) and the programming of the remotes to Unlock your doors (What you want)
Take a look at this post and follow the appropriate directions
https://www.clublexus.com/forums/sc4...ml#post5235725
jmarr
Jan 8, 2012 12:32 PM
