EVAP Code, am I getting ripped off?
Old Jan 17, 2022 | 02:03 PM
Rementis's Avatar
Rementis
Default EVAP Code, am I getting ripped off?
2002 SC430 107k miles.
I got a code P0440, and I can faintly smell gasoline.
Local independent shop says they have to drop the tank, replace some seals/valves/hoses as the leak is coming from that area after smoke test.
$1000 estimate.
Thoughts?
Old Jan 17, 2022 | 02:27 PM
oneround's Avatar
oneround
lots of work to do it the right way - can't say as to labor rates. If you want to go DIY, take a look at these two threads:
Gas smell - ClubLexus - Lexus Forum Discussion
Fuel overfill check valve? - Page 2 - ClubLexus - Lexus Forum Discussion
Old Jan 18, 2022 | 10:22 AM
Harold57's Avatar
Harold57
PO440 can also indicate vacuum hose leaks. Pull the engine cover of (two 10mm nuts) and check out the vacuum hoses for cracks and being loose or off of their mating couplers.
Old Jan 18, 2022 | 10:30 AM
DshngDaryl's Avatar
DshngDaryl
This is what I would do if I were you.
In fact I was you, I was sure my vapor canister over my Gas Tank was leaking, but it turned out it was just the hoses under the hood. This is a VERY COMMON problem on the sc430.
$1000 bucks isn't a rip off for the work that you are requesting, just don't think you should go that route until you exhaust the easier (& Cheaper) stuff first.
Old Jan 18, 2022 | 04:10 PM
gleeson's Avatar
gleeson
i agree to check the hoses first.
i had that same exact code about a year ago.
for me, the fix was replacement of 4 evap hoses. i’ll let the invoice speak for itself…
owner of shop is HS buddy, hence no charge for labor!
part no. on bag may not match the old hose inside.
Old Aug 7, 2024 | 05:48 PM
2002SC430User's Avatar
2002SC430User
2nd gear
Default hoses
Hi, are those 4 hose parts the ones you needed in particular or are these 4 part numbers covering all hoses?
I want to just change all the hoses rather than finding cracked one each time.
Old Aug 7, 2024 | 10:17 PM
sc43069's Avatar
sc43069
$1000 estimate.
Thoughts?
get a second opinion. Trust none of these mechanics. I had a guy tell me I needed a new transmission one time. Knew he was lying . Took the car to another place and he said two screws popped out from the pan. Cost 100 bucks.
btw, I had the same evap code, one of the hoses popped off in the main bay from the timing belt change. He didn’t crimp it back on tight enough
Old Aug 8, 2024 | 08:00 AM
gleeson's Avatar
gleeson
hello, i’m pretty sure those are all the hoses because my HS buddy and shop owner has the same philosophy as you. if one is cracked, others are about to.
might as well change them all since you’re in there.
no codes since 🙂
SCORP69
IS F (2008-2014)
Mar 7, 2019 12:04 PM
RayN
RX - 1st Gen (1999-2003)
Jan 16, 2015 01:16 PM
Hatchman
Jul 14, 2010 04:13 AM
