Shift knob?
Old Jun 15, 2021 | 08:53 PM
jimisbell's Avatar
jimisbell
Default Shift ****?
Is the shift **** on my 2006 the wrong one? It is a light colored wood. almost white, while the rest of the interior is much darker.
Old Jun 16, 2021 | 02:50 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
it may be correct, please post a pic
Old Jun 18, 2021 | 01:39 PM
jimisbell's Avatar
jimisbell
Default ask and you shal receive.
Heres a photo
Old Jun 18, 2021 | 02:24 PM
SC300Es's Avatar
SC300Es
Looks correct to me
Old Jun 18, 2021 | 03:47 PM
GmanSC's Avatar
GmanSC
The light makes the **** looks lighter. If you look at the lower body, the **** is much darker.
Old Jun 18, 2021 | 04:40 PM
jimisbell's Avatar
jimisbell
No, that is an artifact, its the light that makes the lower body in the shadow look darker. The wood is the same intensity top to bottom. I dont even think its the same kind of wood. It is a yellow-blond. The rest of the wood in the car is red
Old Jun 18, 2021 | 05:06 PM
GmanSC's Avatar
GmanSC
You are correct. They are different wood. The shift **** is a solid piece of wood and the rest of your car is just veneer wood on plastic molding body. The shift **** does look lighter on top because the lighting effect. Park your car in the garage, you will see the **** looks darker. Of course, it’s still lighter than the rest.
Old Jun 18, 2021 | 05:15 PM
jimisbell's Avatar
jimisbell
Yes, it is lighter. But if thats the way it is supposed to be, that is fine. I thought it might have been changed by a PO. They should have at least dyed it to match...unless that was intentional and some designer just thought it looked better. I think I will look for a spare, so I dont screw up this one, and see if it can be dyed to match.
Old Jun 18, 2021 | 06:39 PM
jimisbell's Avatar
jimisbell
I wont have to dye one! I found one on EBay that is the right color and right wood~!!
Old Jun 18, 2021 | 07:41 PM
GmanSC's Avatar
GmanSC
I hope you’re right because the picture on the web might not be true color. Most of us here who own the SC with red wood interior have same complain that the shift **** does not match with the rest of the wood.
Old Jun 18, 2021 | 07:45 PM
jimisbell's Avatar
jimisbell
Iwill post pictures. It will be here in a couple of days.
Old Jun 21, 2021 | 01:41 PM
Wilson2000's Avatar
Wilson2000
Is the shift **** supposed to be a different color to go with each of the different wood veneer colors? Or, did the shift **** come in one color only, regardless of veneer color?
Old Jun 22, 2021 | 11:43 AM
2006SC430's Avatar
2006SC430
Originally Posted by SC300Es
Looks correct to me
My 2006 SC430 shift **** looks the same. I have considered swapping it out with one I saw on Etsy that better matches the color and grain. Does anyone know the thread size?
Old Jun 22, 2021 | 03:37 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Thank Wil44, great answer below
Old Jun 23, 2021 | 11:48 AM
WIL44's Avatar
WIL44
The gear shift thread is 8mm x 1.25
