Wind noise fixed
Old May 27, 2020 | 12:08 AM
Cavedog's Avatar
Cavedog
Default Wind noise fixed
Finally fixed wind noise around mirror.The fix is simple. All that is needed is a short piece of 1/4" vinyl tubing. If you push your finger in the rubber molding you will find an opening about an inch from the edge, just push the tubing in there and snip it off at the top of molding. It seems to stay in place just fine. It worked great on the drivers side. It's as quite as my LS is. Today I did the passenger side. I'll let it rest with the window up so the tubing can take set and she will be good to go. If this doesn't last I'll use some silicon vacuum tubing. It will stay nice and round and not squash like vinyl.
No photos. All you need is fingers,1/4" vinyl tubing, and an SC430. Shove the tubing in slot and trim excess.i can not see how I can take photo of tubing in that slot. It is out of sight.
The fix was free. Tubing came from worn out canula.
Old May 27, 2020 | 05:04 AM
maarp's Avatar
maarp
Interesting - can you post some pics?
Old May 27, 2020 | 09:27 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
I too would like to understand how you fixed the wind noise. I kind of have an idea, but pictures always help.
Old May 27, 2020 | 10:14 AM
joemg's Avatar
joemg
+1 for pics, my SC got a little quieter when I fixed the mirror weather stripping, but it's still not as quiet as a regular hard top.
Old May 27, 2020 | 02:04 PM
RK1679's Avatar
RK1679
10th Gear
I'm also following.
digitatc's Avatar
digitatc
I paid $250 for my Airpods pro and it fixes all the noise problem.
j/k, picture would be great. I was about to use some tape to seal up all the seam to see where the god damn noise coming from.
Old May 27, 2020 | 04:02 PM
RRocket's Avatar
RRocket
In for pics!!
Old May 30, 2020 | 03:58 PM
Raven01750's Avatar
Raven01750
Originally Posted by RRocket
In for pics!!
Theres a pocket where my thumb is that has an additional rubber tube installed to give the area more rigidity.
This is the same process used for the top of the windshield and back of the roof line. Hope this helps.
Paul
Old May 30, 2020 | 05:39 PM
digitatc's Avatar
digitatc
If we block those tunnels, how the water is going to flow ?
Old May 30, 2020 | 07:03 PM
Raven01750's Avatar
Raven01750
Just pull the rubber and you will see how its done. Water does not go through the rubber. Easy squeezy
Paul
Old May 31, 2020 | 04:01 PM
RRocket's Avatar
RRocket
Paul
Hmmm...he said the area around the mirror though?
Old May 31, 2020 | 04:21 PM
Raven01750's Avatar
Raven01750
Yes. Just pull the rubber molding. It has a pocket on the backside of the molding. There is a tube of rubber inside the molding to give it some added support where the mirror meets the molding. If the rubber tube inside is partially collapsed, you can pull it out and flop it around. That will probably be enough. OR you can take some aquarium air tubing and insert inside the tube to stiffen it up. No tools required. Just pull.
Paul
Old Jun 2, 2020 | 03:37 AM
RRocket's Avatar
RRocket
Paul
Do you have to pull the moulding out along the A-pillar? Does it go back in easy?
I'm still having a somewhat difficult time understanding exactly where and what to do.
Old Jun 2, 2020 | 06:11 AM
Raven01750's Avatar
Raven01750
I don't know what else to tell you. My picture shows the molding removed, it is easy to pull away and it is easy to put back in place. There was no glue. Just the shape of the molding keeps it in place.
Paul
Old Jun 2, 2020 | 10:25 AM
Harold57's Avatar
Harold57
I think that he is saying that the picture may be too close to provide him perspective as to what the location is. If you would do an additional picture a little farther back to provide more of the surrounding area, it would be more apparent which molding you are referring to.
