Antenna Mast Replacement
Old Jun 27, 2021 | 12:58 PM
  #31
DshngDaryl's Avatar
DshngDaryl
Originally Posted by jimisbell
I dont see the problem. Down here in South Texas we just get a reasonably straight piece of coat hangar wire and stuff one end in where the antenna is "broke off". Sometimes, just for decoration we leave the "hook" end on the top and tie a piece of the old ladies underwear on so we can see it across the WallMart parking lot.....
HA HA
Old Jun 1, 2022 | 05:12 PM
  #32
lab100's Avatar
lab100
2nd gear
Ebay sells a replacement for the SC 430 antenna that works great. Replacement is easy -- it takes about 5 minutes when you follow the online instructions. I just replaced my bent antenna today following the instructions. Nothing to it -- do it yourself.
Old Jun 1, 2022 | 05:40 PM
  #33
Wilson2000's Avatar
Wilson2000
You're replacing the mast only, correct? Is the eBay seller a Lexus or Toyota dealer, or is the one you bought aftermarket?
Old Jun 1, 2022 | 05:59 PM
  #34
lab100's Avatar
lab100
2nd gear
Yes, mast only. My motor works fine. I bent the antenna by forgetting to turn off my radio before entering the car wash. The replacement was probably a Chinese knock-off but it looks just like the original equipment it replaced. The motor grabbed the nylon track right away and the mast descended all the way on the first try. I know some posters have said you need to buy the mast from Lexus (about $60) but I disagree. My reception with the new cheaper mast is no different. EBay sells the replacement now for about $17, shipping included.
Old Jun 1, 2022 | 07:37 PM
  #35
AVSRacing's Avatar
AVSRacing
Mine has had grinding sounds when it goes up or down, It still fully extends though, I just followed the DIY to unplug the motor so it stays down all the time. The radio reception is affected but I don't really listen to the radio anyways.
Old Feb 5, 2023 | 09:08 AM
  #36
SCowner88's Avatar
SCowner88
can someone go over the stubby antenna installation, and parts? thanks
Old Feb 7, 2023 | 07:38 AM
  #37
mandyfig's Avatar
mandyfig
Try this, good luck I have been happy with it and it looks good too.
https://www.clublexus.com/forums/sc4...nna-is-in.html
Old Feb 9, 2023 | 07:42 AM
  #38
MattInLex's Avatar
MattInLex
I used a converter kit and the install took about 2 minutes including reading the instructions. Go to this page and look for "Power Antenna Converter Kit": http://www.theantennasource.com/LEXU...2002-2010.html
I'm very happy with the reception. It also looks good and I don't have to worry about car washes.
One note: I did this as part of replacing my entire audio system, so I did not have to worry about the mast power motor. If you don't clip the power motor, you'll hear it run for about 30 seconds every time you power up the radio. You can clip it behind the radio or pull out the right carpet in the trunk to pull/clip it at the motor.
If you want to see my install, here's the thread:
https://www.clublexus.com/forums/sc4...placement.html
Old Feb 11, 2023 | 06:16 AM
  #39
SCowner88's Avatar
SCowner88
I just bought this antenna, the converter black one, and can you provide even more details on how to change it? I see your thread, would love any additional comments
Old Feb 11, 2023 | 06:27 AM
  #40
MattInLex's Avatar
MattInLex
First step is to remove the existing mast from the power antenna. Here’s a pdf of how to eject the mast. Have someone catch it so it doesn’t scratch the car when it flops off: https://static.nhtsa.gov/odi/tsbs/20...62387-2273.pdf
Then, to remove the silver antenna nut, you just put something like a flat head screwdriver in the slot and tap counter clockwise lightly with a hammer . I used something plastic to keep from scratching the chrome nut.
Once the nut is removed, you put in the converter base, put the nut back on, and screw in the new antenna.
I hope that helps.
Old Feb 11, 2023 | 06:30 AM
  #41
SCowner88's Avatar
SCowner88
thank you, im going to try it this weekend, just a little nervous. Seems so easy, but i dont want to scratch anything,
Old Feb 11, 2023 | 06:37 AM
  #42
MattInLex's Avatar
MattInLex
I know what you mean. I was extra careful but it is very easy.
You can buy a specialty tool to remove the mast nut, which would lower your risk, but really it is not necessary. Just tap carefully and lightly so you don’t slip off it. I had no problems.
Old Feb 19, 2023 | 02:14 PM
  #43
SCowner88's Avatar
SCowner88
So i tried this today with the black flexy antenna that was recommended. I couldnt get the nut back on, so i put it over the antenna and then installed it. THere is a 2mm space under the widest part of the black part, like it isnt seated all the way in. will water leak in? I can screw the antenna fully out, even with the nut in. What did i do wrong? This was supposed to be simple and im frustrated, so im hoping someone could kindly help me.
Old Feb 19, 2023 | 07:25 PM
  #44
MattInLex's Avatar
MattInLex
Did you follow these instructions?
https://www.theantennasource.com/INS...tructions.html
Old Feb 20, 2023 | 05:00 AM
  #45
SCowner88's Avatar
SCowner88
Thanks Matt. I took out a silver colored lug, but didnt see any seals or grommet. i then pulled out the antenna using the process by lexus with the acc-lock position. Then i put in 4-5 inch metal part, and the antenna, and screwed in the nut.
