Nothing works :(
Old Dec 14, 2018 | 11:22 AM
malema's Avatar
malema
Default Nothing works :(
I was trying to get power for a push button from the 15a fuse in the driver foot fuse box second column closets to the door and towards the bottom. My wire was threaded all the way to the middle compartment when it accidentally hit a negative wire. it caught on fire , i turned the car off but now when i try to turn it on, switch opens, climate control has power. radio has not power navigation does not work and it does not cranck. I checked and the fuse is ok(connected). but its brown on the positive side where i took power from. any idea what could be it/could possibly fix it? I know its a long shot
Old Dec 14, 2018 | 11:29 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
did you replace the fuse already?
Old Dec 14, 2018 | 11:50 AM
malema's Avatar
malema
no but i tested the fuse and it works
Old Dec 14, 2018 | 11:55 AM
DaveGS4's Avatar
DaveGS4
I'd replace it regardless if discolored to start off. Inspect others as well
Old Dec 14, 2018 | 12:51 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
post a picture of the fuse in question.
there are main fuses in another location and one of those may have blown.
i have the schematics of the car.
Old Dec 14, 2018 | 01:39 PM
DshngDaryl's Avatar
DshngDaryl
Hopefully the fuses in your car did their job and blew when you shorted the wires.
Now the tough part is to figure out which fuses blew.
You can test them in place with a multi-meter. Just set your multi-meter to OHMS and put your probes on the little metal parts of the fuse tops.
For a more detailed explanation, you can watch this video
Old Dec 14, 2018 | 06:32 PM
GmanSC's Avatar
GmanSC
For the few bucks, go to Harbor Freight and purchase the circuit tester. You can test all the fuses in the car in no time.
Old Dec 15, 2018 | 08:10 AM
Harold57's Avatar
Harold57
There's also the chance that the fire either damaged contacts or singed them enough to make the contacts intermittent or unreliable. You might have to go in and clean the contacts or worse, replace the fuse box. Hopefully it is just another fuse or two somewhere that need to be replaced.
Old Dec 16, 2018 | 01:50 PM
DJWLDW's Avatar
DJWLDW
Did you not have a piece of electrical tape over the end of the wire as you feed it down the inside of the kick panel?
Dennis
Old Dec 16, 2018 | 01:57 PM
Htony's Avatar
Htony
Checked big fuse link?
dacommitte
NX - 1st Gen (2015-2021)
Feb 15, 2019 08:52 AM
Mantist
Jul 5, 2018 06:18 PM
socaligs
Feb 1, 2017 10:31 PM
Ktran1039
Apr 11, 2016 08:56 PM
desmo907
RX - 3rd Gen (2010-2015)
Jun 21, 2013 09:07 AM
