TPMS Testing and Programming with TechStream 2002-2006
Old Jul 2, 2018 | 12:33 PM
  #46
iolmaster's Avatar
iolmaster
Just a follow up. I had the new tires with the new TPMS sensors installed today at Firestone. I have an 06 so I have the color coded sensors. I bought the Toyota sensors not the Denso. Probably the same thing. Both were essentially the same price. The manager at Firestone felt very confident that they would be able to mate the new sensors to the ECU. I had my doubts. Well, I was right. He said they tried everything they knew and were not successful. I do have Techstream on an old computer so I felt confident I could do it. I had my wife stay at the computer and I entered the program mode and started letting air out. She would tell me when each sensor programing was successful and I just went around the car letting air out until all four were entered. TPMS light went out and all is well. The local Toyota store wanted about $200.00 for the service. If I only use this cable once in my life I am way ahead.
Old Jul 2, 2018 | 01:45 PM
  #47
Bgw70's Avatar
Bgw70
Veteran: Air Force
you could purchase eight cables and copies of TechStream for that kind of money!!!
i know I’ve saved a bunch of money using TechStream to program my TPMS sensors, change car settings and run diagnostics over the last few years!
my total investment was $65...$25 for TechStream with the cable and $40 for an old Gateway mini laptop with WinXP.
Old Oct 29, 2020 | 07:56 PM
  #48
deejay2005's Avatar
deejay2005
7th Gear
Hi.
Where can I get cable and TechStream that will work to program new TPMS sensors? I've seen them on Amazon and ebay but not the best reviews.
I'm in Tampa Bay, FL. Anyone local here to help?
Thx
Old Oct 30, 2020 | 10:24 AM
  #49
GmanSC's Avatar
GmanSC
Originally Posted by deejay2005
Hi.
Thx
Remember, you are buying the bootleg copy of very expensive software that Toyota and Lexus dealers are using. Most, if not all, products you see on Amazon, EBay...are from China. You just have to bite the bullet and hope for the best. Most of us here have no problem. I wish I could give you my vendor but unfortunately he’s out of business.
Old Oct 31, 2020 | 03:16 AM
  #50
Bgw70's Avatar
Bgw70
Veteran: Air Force
Hi.
Thx
Well, I live due East of you on the opposite coast...two hour drive.
Make a trip over here and I will program them for you.
BTW, did you ever get your AC working correctly?
Old Oct 31, 2020 | 07:22 AM
  #51
deejay2005's Avatar
deejay2005
7th Gear
Hi.
Thank you for the offer. Will try to do it myself first and we'll go from there.
Yes, AC was fixed by replacing compressor and condenser.
Regards
Old Nov 17, 2020 | 01:56 PM
  #52
RC51's Avatar
RC51
Very informative thread. Thanks so much. It would appear that any color TMPS sensor can be replaces with any other color TMPS sensor using the programming procedure through TechStream. What am I missing?
Thanks
David
Old Nov 17, 2020 | 05:06 PM
  #53
Bgw70's Avatar
Bgw70
Veteran: Air Force
Thanks
David
as long as you don’t use the same color twice...you must have all four colors.
red
blue
yellow/gold
white
Old Nov 17, 2020 | 06:53 PM
  #54
RC51's Avatar
RC51
red
blue
yellow/gold
white
Ah ha !! Thanks. I did not know that !! Thank you kindly.
Old Jan 24, 2021 | 03:53 PM
  #55
Bgw70's Avatar
Bgw70
Veteran: Air Force
I just found this set of TPMS sensors for our 2002-2006 SC430s...$320 seems to be a decent price
https://www.ebay.com/itm/NEW-GENUINE...wAAOSwSmJfLM0E
Old Jan 24, 2021 | 04:20 PM
  #56
daddiojigg's Avatar
daddiojigg
Is there a way to tell which monitor is bad? Ie. left rear, right front
I replaced all sensors at the same time but never made notes on which colour was where.
Old Jan 24, 2021 | 04:29 PM
  #57
Bgw70's Avatar
Bgw70
Veteran: Air Force
Great question...yes, if you have Techstream you can indicate which color sensor in each wheel, either reprogram or reduce the air in each tire, then look at Techstream for the reduced air pressure.
if you have a sensor at 1.8v, it may not respond to an air pressure change
Refer to this link, posts #29 and #30 for more details.
https://www.clublexus.com/forums/sc4...l#post10028771
Old Jan 25, 2021 | 09:20 AM
  #58
ESC43's Avatar
ESC43
Hi. Not sure if anyone monitors this thread any more but I am smack dab in the middle of some TPMS pain. I bought OEM Sensors from Ebay for my 2006 SC but my mechanic won't install because he claims his reader doesn't pull a frequency. I explained to him he just need to install and I would take over using a copy of Techstream and a VCI cable but he doesn't want to. Is that a thing? "pulling a frequency"? Is there a way to tell if these new sensors are actually good? Also I haven't even gotten to the Techstream part of my project yet and am starting to lose patience. If anyone knows anyone in the Chicagoland area that has Techsteam. and can program these I'd be grateful. even the Toyota dealer wants 150 bucks a wheel which seems insane.
Old Jan 25, 2021 | 09:46 AM
  #59
daddiojigg's Avatar
daddiojigg
The way i see it ; your only problem is with the install. Once you have them installed you can take over-- don't give up on the techstream so fast. You'll be glad you persisted.There are ways of installing yourself(check YouTube). The only thing i would be concerned with if you did it yourself would be balancing but i figure your just replacing like for like so there shouldn't be any weight difference.I can't understand why he wouldn't install but maybe he sees it as a liability issue. If you feel he's competent, give him a pass on any damage he may do.
Bgw: either reprogram or reduce the air in each tire, then look at Techstream for the reduced air pressure.
if you have a sensor at 1.8v, it may not respond to an air pressure change.
yes, I thought that would be a way but i was looking for the easiest,laziest method !!
Old Jan 25, 2021 | 10:10 AM
  #60
Harold57's Avatar
Harold57
Discount Tires will install them, I believe that Costco will also.
