CD Jammed in stereo
Old Aug 21, 2015 | 03:27 PM
pikacindy's Avatar
pikacindy
10th Gear
Hi I just had this problem happened to me first time after 6 years of driving my SC430, and I AM NOT paying freaking $830 for lexus dealership to fix it for me either, i read somewhere that you can disconnect the battery, I went to a car shop that is nice enough to disconnect the battery for me and after 10 minutes of disconnecting, it works!!!! I tried all other way and it didn't work (such as getting jammed CD out, turning on and off on stereo), the car place taught me to disconnect the positive side (i watched him did it), this should works. However, after battery reconnecting, the car seat memory got erase and I couldn't set it up again, I'll just get lexus to fix it for me for free when I go back for recall next time
Old Aug 22, 2015 | 05:54 AM
mandyfig's Avatar
mandyfig
Read your manual, there are simple steps to set you car seat memory.
Set you car, adjust as needed, seat, steering wheel and side mirrors.
Hold SET, while holding Set, push our number (1 or 2) and you will hear a beep.
You are all set.
Old Aug 22, 2015 | 09:52 AM
Harold57's Avatar
Harold57
You may have to re-calibrate your seat ECU. If it loses the maximum forward and reverse positions, it will not allow you to set the locations again until after it is re-calibrated. (Re-calibrating is a fairly simple procedure. It is documented in the forum, maybe even in the manual but I'm not sure.)
Old Aug 22, 2015 | 05:30 PM
bb430's Avatar
bb430
To recalibrate your seats memory, I believe you need to power slide the seat all the way forward till it stops moving then all the way backward till it stops, then you should be able to set your memory seats.
Old Aug 22, 2015 | 06:54 PM
Harold57's Avatar
Harold57
Check out the advice in this thread, especially posts # 8, 11, 12 & 13.
https://www.clublexus.com/forums/sc4...d-strange.html
Old Apr 28, 2018 | 05:07 PM
Roho's Avatar
Roho
Ha!!
Smack it!! Like WWE Monday Smackdown, Ironically I tried it on a Monday night and it worked.
I think trying it on a Monday is what made it work.
(wink-wink)
Old Apr 28, 2018 | 06:58 PM
GmanSC's Avatar
GmanSC
I don't like the CD changer, nothing but trouble. Gosh, I don't even listen to the CDs, I use Iphone music player or youtube. If I must listen to the CD, I just load a single.
Old Apr 28, 2018 | 07:14 PM
Roho's Avatar
Roho
yeah, same here, I don't use the CD neither, but for those that need to get the CD's out and might want to use the CD player, the smack on the side worked.
I use the aux set up to listen to Pandora or YouTube etc.
johnnylt
Aug 30, 2020 11:31 PM
FactoryRX
Sep 5, 2017 07:25 PM
i3leusky
Apr 6, 2015 02:09 PM
4titude
Jul 15, 2007 03:41 PM
sumtingwon
Oct 15, 2004 08:21 AM
