climate control stuck
Old Jan 3, 2014 | 02:22 PM
LEXZILLA's Avatar
LEXZILLA
Default climate control stuck
hi guys
i have a 03 sc430 will a stuck climate control.
i can change the temp on the passenger side,
but the drivers side is stuck on 65!
and its cccold here!!!!
any help would be appreciated
thanks
Old Jan 3, 2014 | 04:17 PM
mrblister's Avatar
mrblister
Originally Posted by LEXZILLA
hi guys
thanks
You can switch between dual control and single control Try it both ways
Old Jan 3, 2014 | 05:00 PM
LEXZILLA's Avatar
LEXZILLA
i tried that it still stays at 65!!!
and blows cold air on the drivers side
can this climate control be reset????
Old Jan 3, 2014 | 05:10 PM
mrblister's Avatar
mrblister
Sounds like a servo motor problem [ Door is not opening ] Do both sides of the defrost blow hot as well as cool. Cycle your flow controls see if you can unstick it.
Old Jan 3, 2014 | 05:33 PM
LEXZILLA's Avatar
LEXZILLA
naw it just blows cold
Old Jan 5, 2014 | 04:11 AM
FLYCT's Avatar
FLYCT
The first thing to try to resolve any computer problem is to "POPO" it. Power Off, Power On. Try disconnecting the car battery for 30 minutes and reconnecting it. It may reset the stuck climate control computer setting.
The only down side is you will have to also reset seat and side view mirror memory, and possibly any radio preset stations. Oh yeah, forgot that your navigation system will revert to default settings, I.e., you may have to reset geographic zone, toll road selection etc. it's not a big deal. It only takes 5 minutes to reset everything.
JR.
Old Jan 6, 2014 | 11:40 AM
LEXZILLA's Avatar
LEXZILLA
update:
i disconnected the battery for about an hour,
reconnected battery and the climate control read 75 ,
i adjusted the temp to 70 and tried to set it back to 75 and it does not move.
any other thought? advice?
thanks in advance
Old Jan 6, 2014 | 12:04 PM
FLYCT's Avatar
FLYCT
update:
thanks in advance
Inop temp UP switch? Temp can be lowered but not raised?
Perhaps a shop that repairs car stereos can look at it.
JR
Old Jan 6, 2014 | 02:31 PM
kjcole's Avatar
kjcole
You may be shopping ebay for a climate control module. There are a few on there now that are under $300.
Old Jan 6, 2014 | 07:16 PM
mandyfig's Avatar
mandyfig
FLYCT is right, the contacts on the UP is probably not closing.
audenried
Oct 20, 2022 12:16 PM
vinceiscoo
Apr 5, 2012 07:31 AM
Sui3z3ro
Jul 4, 2009 02:49 PM
rickjaffe
Jan 21, 2009 05:09 PM
GoldieLex
Jun 16, 2005 03:18 PM
