Problem with side mirrior tilt when backing up
Old Nov 25, 2012 | 12:37 AM
gizmatix's Avatar
gizmatix
Default Problem with side mirrior tilt when backing up
At first the drivers side, side mirror would tilt as it should when backing up but when i got onto the street from my driveway wouldn't stop tilting up-words till it made a clicking noise that it wanted to keep tilting but couldn't. The only way to stop it was to adjust the side mirror manually and tilt it down and it would stop and stay at whatever i set it as. Now it just doesn't tilt at all.
Has anyone experienced this? What part numbers would i need to fix the problem? Does anyone have instructions on how to go about fixing this?
I drive a 2002 SC 430. HELP PLEASE
Old Nov 26, 2012 | 04:40 AM
gizmatix's Avatar
gizmatix
really, no one has ever had this happen to them?
Old Nov 26, 2012 | 06:33 AM
OBP's Avatar
OBP
I had a similar problem with my passenger side mirror. The car was CPO at the time so the dealer replaced the whole mirror assembly including the housing.
Old Nov 26, 2012 | 11:39 AM
gizmatix's Avatar
gizmatix
thanks for the reply OBP
Does anyone know how much it might cost to replace the whole assembly on my Lexus? Or where i could look up the part numbers? My car came from a gov auction, so i don't think theres any type of warrantee included with my car. Especially since it was build 2002 =/ just my luck....
Old Nov 26, 2012 | 06:57 PM
FLYCT's Avatar
FLYCT
Go to Sewell Lexus Online. Register with your ClubLexus user name for special discount.
Looking at the site it looks like discounted price for drivers side ranges from $223-$490 depending on color. Passenger side about $360.
You must log on with your CL account to get discount price displayed.
Part number 87910 passenger side and 87940 driver side
http://lexus.sewellparts.com/oem-cat...C430-2002.html
JR
Old Nov 30, 2012 | 04:19 PM
Harold57's Avatar
Harold57
Yes, this problem has shown up in the past. Do a search on the forum to find how folks have treated it. The problem is the plastic gears in the mechanisms wear out over time and die. The noise you were hearing was likely the gears trying to turn in a spot where a tooth broke off.
IIRC, someone purchased a rear view mirror and just replaced the guts of the old one with the purchased one.
Old Dec 3, 2012 | 11:24 AM
toxic's Avatar
toxic
Am I correct in assuming only the drivers side mirror tilts when the car is put into reverse or do both driver and passenger mirrors automatically tilt? Only my drivers does.
TOXIC
Old Dec 3, 2012 | 12:15 PM
FLYCT's Avatar
FLYCT
TOXIC
Both tilt on mine if the selector switch is either set to RT or LFT. If switch us set in middle neither mirror tilts.
I park on right side of my garage and I always use the tilt feature to make sure I clear the garage door frame on the right side, when backing out.
JR
Old Dec 4, 2012 | 09:28 AM
FLYCT's Avatar
FLYCT
TOXIC
Here's a quick video of my passenger mirror tilting when car is put in reverse.
JR
Old Dec 4, 2012 | 10:29 AM
gizmatix's Avatar
gizmatix
Both drivers side and passenger side on my 2002 SC tilts as well. But when going back on level ground and it tilts back to where its suppose to be it doesn't stop going. Till the gears start making a noise and i have to hold a the tilt button to set it back to where it should be.
FLYCT:: the part numbers you've listed, is that the same parts that include the motor?
Old Dec 7, 2012 | 04:57 AM
toxic's Avatar
toxic
Alrighty then......Looks like I have a motor out on the passenger side....Don't really think it's worth the hassle of deconstructing though.
TOXIC
FishinAJ
Maintenance
Jun 22, 2015 10:53 AM
srumman
HS 250h Model (2010-2012)
Mar 31, 2015 09:59 AM
Sceanzo
May 27, 2014 06:07 PM
Btmnk21
RX - 3rd Gen (2010-2015)
Jun 1, 2009 05:57 AM
minnister
Jul 15, 2008 08:14 PM
