Navigation help
Old Sep 8, 2007 | 09:15 PM
John007's Avatar
John007
Default Navigation help
Hi, guys yes I do know this has be discuss already, but does any remeber how to input a address or destination while driving? I know about the 05 and up hack for this but does any one the 03 one with the navigation 2 and 3 hack? I know the 05 and up one which is the volume control tapping. i have tried that one on my 03 and it doesn't work.
Old Sep 9, 2007 | 05:42 AM
tfischer's Avatar
tfischer
25 Year Member
Well, if, as you say, "this has be discuss already," then my guess is that the Search Guy remembers.
And, usually, his English has be much more better.
Old Sep 9, 2007 | 11:36 AM
SC430Sam's Avatar
SC430Sam
Where is the hack for the 05+? Does it involve cutting wires?
Old Sep 9, 2007 | 08:00 PM
JohnnyCake's Avatar
JohnnyCake
No, but it involves mucking around every single time you get in the car. Not worth it.
Old Sep 9, 2007 | 10:40 PM
Roofless's Avatar
Roofless
CL Folding 500,000
(1) press "MENU" button
(2) press "System Option" on screen
(3) press top-left corner of screen
(4) press bottom-left corner of screen
(5) press top-left corner of screen
(6) press bottom-left corner of screen
(7) press bottom-right corner of screen
(8) press "OVERRIDE" in the new menu
(9) press "BACK"
Old Sep 10, 2007 | 07:16 AM
SC430Sam's Avatar
SC430Sam
So this is not a permanent command? It has to be done each and every time your enter the car?
Old Sep 10, 2007 | 08:00 AM
tfischer's Avatar
tfischer
25 Year Member
Not technically. The NAV system, as smart as it is, does not know if you have exited or entered the car. The command sequence has to be done each and every time you start the engine.
For two reasons, I stopped using this several months after learning about it several years ago (and it works on both of my Lexus cars). First, the codes have to be re-entered every time you start the car, and this cannot be done while the car is in motion. Since you only think to use it while in motion, and often on expressways, this limits its implementation a lot.
Secondly, it's not that helpful, and it's quite distracting and even an experienced and excellent driver, like me for instance, finds that entering searches and new destinations while driving is an accident waiting to happen. Changing the iPod to a new playlist or looking up a number in a cell phone directory is about as much distraction from the road as I want to risk. Messing with complex navigation system changes while driving has "hospital" written all over it.
It's a nice trick to know, but after trying it a few times, I just quit, and I don't miss it at all.
(These considerations do not take into account that a passenger could be doing the NAV changes, which could be the case in some instances, which would make a difference. But for solo trips, I just don't bother anymore.)
Old Sep 10, 2007 | 09:45 AM
paul_k's Avatar
paul_k
New destinations can be added just by touching the screen and moving the map while driving.
Old Sep 10, 2007 | 10:11 AM
tfischer's Avatar
tfischer
25 Year Member
While it's true that, as noted above, "New destinations can be added just by touching the screen and moving the map while driving," this has limited use, especially if you want a destination that you cannot find on a map.
For the most part, destinations from "Marked Points," "POI," or "Previous Destinations" cannot be entered while the car is in motion, and the "in motion" cutoff happens at about 2 mph (even though my doors don't lock until 11 mph).
Exceptions that I have seen are the "Home" button which is always available for a quick getaway, and in my '02 SC430 (Gen 2), page 1, but not page 2, of "Previous Destinations" is available. Sometimes I will use this to load up 5 places I might want to add on the fly. However, on my '04 RX330 (Gen 3), the ability to access any of the "Previous Destinations" pages has been removed. In that car, the only destination available while the car is in motion is "Home."
Some POI's can be called up, like gas stations, so their icons appear on the map as you drive by (at the .5 mile scale or less). Touching the icon brings up an info screen, which often includes a phone number and a street address.
But that's about it, unless you enter the unlock code, which is designed for testing the system.
Still, having the NAV system is "much more better" than having no NAV system.
Old Aug 15, 2008 | 12:11 PM
rem1acs's Avatar
rem1acs
(9) press "BACK"
I have a rx330 05 that I can unlock the nav with the menu/volume but the phone stuff is still grayed out, can someone tell me how to unlock the phone also.
Old Aug 15, 2008 | 01:02 PM
Habious's Avatar
Habious
Probably would be a question best asked in the RX forum.
Old Aug 15, 2008 | 01:29 PM
IcEnPinKi's Avatar
IcEnPinKi
And, usually, his English has to be much more better.
Old Aug 15, 2008 | 01:58 PM
tfischer's Avatar
tfischer
25 Year Member
"During August, question marks are always optional."
--- Interweb Revised Rules of Grammar, 2005 Ed.
Old Aug 15, 2008 | 02:55 PM
JohnnyCake's Avatar
JohnnyCake
At least in the 06 generation, the hack via the volume control can be done with the vehicle in motion, although I agree it is dangerous.
mss1234
15
Aug 2, 2016 01:19 AM
2014GS350F
Mar 2, 2015 07:27 PM
pat70
GX - 1st Gen (2003-2009)
Dec 30, 2009 09:42 PM
lbc99
Oct 13, 2007 03:01 PM
gappell
65
Dec 16, 2006 02:26 PM
