Power top trouble
Old May 25, 2025 | 10:29 AM
DshngDaryl's Avatar
DshngDaryl
The chime means your car thinks the roof isn't all the way closed. That is also why your trunk release button doesn't work.
Try pushing the TOP Close button and see if it will go just a little more.
If not, you will have to manually open it.
My guess is that you have something blocking one of the holes where the roof pins go in.
Old May 25, 2025 | 06:03 PM
GmanSC's Avatar
GmanSC
It may misaligned. Need to calibrate the left and right balances. I don't know how.
Old Jun 1, 2025 | 07:08 PM
Losit's Avatar
Losit
8th Gear
Default Success!!
First, thank you to all who responded. Kept me motivated.
Went out to work on the top again, but decided to wash her first. I live in an area with LOTS of pollen and anything else that falls from trees. Still had solid red on the switch.
As I washed, I cleaned the drain channels along the trunk. Closed trunk and light went out. Hit the open button and wI does moved but stopped, and trunk release started working. I cleaned the channels very well and wha-laaa….top now operates flawlessly again!!
No dealer needed! Thanks again!
Old Jun 2, 2025 | 10:27 AM
DshngDaryl's Avatar
DshngDaryl
CONGRATULATIONS! That is great news.
I am afraid it may be short lived though; After a problem things tend to clear up and then go bad again.
Let's hope that is not the case for you
Peeek
Jul 12, 2018 08:40 AM
bstarr34
Jul 29, 2015 04:47 PM
416tt
Apr 18, 2015 10:21 PM
ItsAlive
Mar 16, 2015 08:58 AM
986ci's
Jul 6, 2009 01:14 AM
