Power trunk release not working....
Old Jul 16, 2015 | 07:40 AM
bstarr34's Avatar
bstarr34
Default Power trunk release not working....
So recently my interior power trunk release stopped working. The one on the key still works.
Has anyone dealt with this yet?
Thanks
Old Jul 16, 2015 | 10:16 AM
Mcon's Avatar
Mcon
First, check your fuses to see if one is out and if all your fuse are good check the contact wires plug on the release motor. Also, you can try WD40 to see what happen on the switch to see what happen?? If check all and all are good, your release motor are gone.
Old Jul 16, 2015 | 10:30 AM
GregCanada's Avatar
GregCanada
Contact wires and fuse will be fine since the trunk still operates it.
Please DO NOT EVER spray WD40 on your electrical swtiches!!!
You can get some electrical contact cleaner to fix up the switch.
Personally, the first thing i would do would be to remove the switch, disassemble it (if possible) and clean up the contacts (use sandpaper or electrical contact cleaner). Look out for any broken solder joints (if so, re-solder them). Typically on Toyota's/Lexus's, the simple fix is usually the correct fix. I had the same issue on my rear window defrost button and fixed it rather quickly. The switch may also have been unplugged - check that first!
Old Jul 16, 2015 | 07:25 PM
Mcon's Avatar
Mcon
When I said WD40 on the switch is where the lock switch close and open to release the trunk. No inside of the motor switch. Just to clarify what I try to say. I personally I use the WD40 in that area and that plastic part start work 100% better. That is my experience. I hope and you can found what ever the problem that you have with that motor switch and fix it sooner.
Old Jul 16, 2015 | 07:48 PM
Mcon's Avatar
Mcon
QUOTE=GregCanada;9115515]Contact wires and fuse will be fine since the trunk still operates it.
Personally, the first thing i would do would be to remove the switch, disassemble it (if possible) and clean up the contacts (use sandpaper or electrical contact cleaner). Look out for any broken solder joints (if so, re-solder them). Typically on Toyota's/Lexus's, the simple fix is usually the correct fix. I had the same issue on my rear window defrost button and fixed it rather quickly. The switch may also have been unplugged - check that first![/QUOTE]
GregCanada,
Sorry but I do not understand you?? On your first comment you say that the contact wire and fuse will be fine sice the trunk still operate it. And your last comment you say, may also have been unplugged. Sorry again, but for me that no make any sense?
You can open you truck with your key and the internal motor open switch be bad?
Also, bstarr 34,
you inadvertently you have activated the button of the valet parking that is on your dash and that makes you to not open the trunk with the beeper. Use your regular key and turn off the switch and see if the trunk open this time. Good luck and God bless U. .
Old Jul 19, 2015 | 08:14 PM
GregCanada's Avatar
GregCanada
MCON - he says the switch up front is not working. That is why i say it may be unplugged. He says the trunk release works fine from the key FOB. That is why i'm thinking there is something wrong with the switch.
Old Jul 20, 2015 | 09:53 AM
bstarr34's Avatar
bstarr34
Default re: Trunk release
The trunk release inside the car stopped working after I locked my keys in the trunk with the car locked. I had AAA break into the car. The alarm went off....
I think the release stopped working after that. I don't think there is something wrong with the car.
I think it's a reset of some sort.....IMO.
Thanks for all your help guys.
Old Jul 23, 2015 | 12:00 PM
Mcon's Avatar
Mcon
I'm glad that are you were able to solve your problem in one way or another. I was all thus this weekend thinking what maybe was the reason why that switch go bad. :-)
Old Jul 29, 2015 | 03:00 PM
dhurghamj's Avatar
dhurghamj
Default Same Problem in LS460 2007
Hi
Hi
I have same problem with my LS460, 2007
Can somebody post video what should I do ?
Old Jul 29, 2015 | 04:47 PM
Mcon's Avatar
Mcon
Originally Posted by dhurghamj
Hi
Hi
Can you go to the forum for LS 460 and ask there. Maybe one of the member in that forum let you know or have a pictures of video for it.
MUDHAR
Jan 27, 2017 10:47 AM
ItsAlive
Mar 16, 2015 08:58 AM
LS400BOY
Jan 20, 2015 11:53 AM
986ci's
Jul 6, 2009 01:14 AM
Krayziedxc
May 1, 2009 11:23 PM
