Need Help with Code
Old Feb 3, 2024 | 11:38 AM
DJWLDW's Avatar
DJWLDW
Default Need Help with Code
The check engine light came on along with the VSC/VSC Off light on the sons 05 SC430. He hooked up the laptop with techstream and found the following codes
P0441: Evaporative Emission System Incorrect Purge Flow. Current and Pending boxes are checked.
P0446 Evaporative Emission System Vent Control Circuit Pending box is checked.
P0455 Evaporative Emission System Leak Detected (large leak) Current and Pending boxes are checked.
Not sure what those codes are telling him
Thinking this might be a gas cap issue. Thoughts?
Thanks for the help.
Dennis
Old Feb 3, 2024 | 10:09 PM
Wilson2000's Avatar
Wilson2000
I've seen this problem written up several times over the years. I believe there are a couple of valves controlled by solenoids, either of which could be bad. From what I remember, the one in the back by the gas tank is a ***** to get at, and it's the more likely one to fail. Another valve exists under the hood. A vacuum leak in any number of lines in the evap system could also be to blame.
Search the forum for this and you might get some specific info on how to approach fixing it.
Old Feb 4, 2024 | 05:32 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Dennis, Wilson is correct.
focus on a vacuum leak first.
this happened to me but I didn’t have the P0455, I had P0440 plus the other two.
I replaced my gas cap but it didn’t correct the problem.
it was vacuum lines on the drivers side of the engine.
remove the cover and carefully look and touch each line starting on the drivers side.
those are the most common and don’t focus on the fuel tank until you’ve confirmed the vacuum lines in the engine area.
https://www.clublexus.com/forums/sc4...l#post10659592
Check the drivers side first.
Old Feb 6, 2024 | 06:34 AM
lifeisgoodsteve's Avatar
lifeisgoodsteve
4th Gear
Good to know.
Old Feb 7, 2024 | 04:19 AM
DJWLDW's Avatar
DJWLDW
Well no apparent vacuum leaks detected so ordered up a new OEM Gas Cap.
Dennis
CandorBear
Aug 27, 2020 05:29 AM
Mr.Wi66L3z
Sep 24, 2018 10:48 AM
billymowat
Nov 6, 2013 05:39 PM
06pearlex
Apr 2, 2011 12:46 PM
waxman
Feb 2, 2009 09:45 PM
