help!!!!! check engine light and vsc light
Old Mar 29, 2011 | 09:48 PM
06pearlex's Avatar
06pearlex
Default help!!!!! check engine light and vsc light
when i was going home from work my check engine light and my vsc light turn on at the same same and i dont know what it could be........
please help!!!
Old Mar 29, 2011 | 09:53 PM
MarkoJames's Avatar
MarkoJames
mine was a "system too lean" code, with which lexus changed my oil, fresh tank of gas, and called it good. been perfect ever since. the combination of these lights varies, so you'll have to grab an OBD II scanner, and get it checked out.
Old Mar 29, 2011 | 09:54 PM
edgeucated's Avatar
edgeucated
either you get the error code read or you need to provide us with more info, such as what you were doing earlier, did you install anything?
Old Mar 30, 2011 | 06:17 AM
calvin2376's Avatar
calvin2376
The VSC light always comes on with a Check Engine Light, as a CEL causes the car to shut off the VSC system. So the issue is likely not with the VSC system. You have to at least provide a code (obtained using an OBDII scanner, which you can get for $30 at Autozone or on Amazon) for people to help.
I had a CEL come up and my VSC light came on (as it always will), and it turned out to be a cracked gas cap. First step for you is check your gas cap is tight. Then, check the code with a scanner or take it to an Autozone type place, which will usually check the code for you for free. Only use the code info they provide you, do not take their advice on how to fix it or agree to anything they propose, they'll just want to upsell you on something you probably don't need. They start foaming at the mouth when people come in asking for a code read because that tells them the person doesn't know much about their car and will be gullible and buy whatever expensive crap fix they propose..
Old Mar 30, 2011 | 06:43 AM
LILLEX350's Avatar
LILLEX350
I'm getting P0171 and P0174 Bank 1/Bank 2 System too lean codes right now as well on the 07 IS350 we just picked up two days ago from carmax. I'll post up what it ends up being (car is 100% stock with 52k miles)
Old Mar 30, 2011 | 06:55 AM
calvin2376's Avatar
calvin2376
Very helpful page here: http://repairpal.com/OBD-II-Code-P0171-and-P0174
Could be a lot of things, but one thing that jumped out at me on that page was the PCV valve, which I've read on the CL forums is a semi-common issue on the ISX50. In fact, my dealer recommended it be checked at the 60k mile mark (I'm currently at 58k) for that reason.
Please do post what it end up being, quite curious.
Old Mar 30, 2011 | 08:11 AM
JDMis350's Avatar
JDMis350
i have the same problem in my 06 too. ran the scanner on it a while back and it threw the same codes bank1 bank2 system too lean.i used to reset the ecu to turn it off or the scanner to erase the codes and if it came back on then u know its soemthing. but after the 3rd time of it happening AFTER lexus decided it was just my oil i stopped bringin it there. and finally i changed my MAF sesnsor and since then it was fine. threw a scanner on and the codes never came up, i jus had low coolant cel but since then never had system too lean codes.im not sayin this is the fix but from what i read our problem sounds similar so i thought id share.goodluck
also i noticed the cel always came on when it was cold
Old Mar 30, 2011 | 09:40 AM
Bichon's Avatar
Bichon
please help!!!
Any time this happens, the first thing I'd check is for a loose gas cap. If that's not it, find somebody with a code scanner to read the codes (Autozone stores will do it for free); without knowing what the DTC codes are you are just guessing.
Old Mar 30, 2011 | 01:55 PM
MarkoJames's Avatar
MarkoJames
ah, forgot to mention - they also did the fuel pressure sensor tightening recall while i brought it in for this issue.
Old Mar 30, 2011 | 04:58 PM
06pearlex's Avatar
06pearlex
i just went to autozone and the code p2004 ....the intake manifold runner stuck open bank 1
where is that located on the engine ?
Old Mar 30, 2011 | 09:17 PM
Lexustom's Avatar
Lexustom
Had this same thing happen on my '06 IS350. Yup, loose gas cap. It did not "heal" itself though. Took it to my service advisor at the Lexus dealership and he reset it for me for zero $.
Old Mar 30, 2011 | 09:24 PM
650IS350's Avatar
650IS350
Loose gas cap, roll around for a while. ECU will reset it self. just had that a week ago. tighten it more than the 1 CLICK was the cause.
Old Mar 31, 2011 | 06:08 AM
AaronN's Avatar
AaronN
You're all very fortunate. I got these lights this past Sunday night along with "Check VSC" in the display, and now my car (08 IS350) is at the dealership getting a new engine. Apparently, when the valve spring recall was done a few months ago, something wasn't torqued to spec, and the timing chain got loose.
Old Apr 1, 2011 | 03:19 PM
650IS350's Avatar
650IS350
you should be lucky then as you are the one getting a new Engine.....
Old Apr 2, 2011 | 12:46 PM
Clay Easto's Avatar
Clay Easto
'07 250AWD, 45K miles - my CEL has come on three times in the last three months.
1st time they did the top end cleaning.
2nd time they said no codes were stored, no problems.
3rd time (yesterday) i took it to Napa Auto to have them check the codes.
This is what they found - 1) P0500 Speed Sensor, 2) P0894 Transmission Component Slipping, 3) P2714 Pressure Control Solenoid Performance.
Any thoughts before I take it to the dealer again?
Thanks for any and all help, I really appreciate it.
Icy350
Dec 9, 2025 11:11 AM
GBunce
Jan 9, 2024 09:11 AM
BPVIP
GX - 1st Gen (2003-2009)
13
May 7, 2012 03:08 PM
rhwimmers
Oct 5, 2009 08:36 AM
kidluvsole
May 26, 2008 07:32 PM
