Marcus' '92 Build
I've got an idea of how I can get the cut-outs to sit higher... Basically I'll use a jack in the area where the cut-out sits and since it isn't a good jack point, I'll just use the vehicle weight to push the floor board up some to make space for it.
The measurement is from the front of the bellhousing(engine block mating area, to the center of the shifter tripod. This is important because I'm going to have to cut/drill a hole into the transmission tunnel for the tripod to stick through.
The current W58, non-tripod measurement is 26 7/8", new shifter is at 31 14/16". So I'll drill a 4" hole just shy of 5" back from the current center line of the shifter.
Next, I need to pull the engine, swap over the new pilot bushing, flywheel, and clutch, put the transmission onto it and drop it back into the car!
1) buy a new head... Would rather not do that
2) Tap the EGR hole and put a big (15mm) screw/plug into it - I’m deleting the EGR anyway.
https://www.amazon.com/dp/B01MEFKNX4..._t1_B00V0R7LVI
3) Put a freeze plug in the hole
4) take it to a machine shop and see if they can do anything for me
Any suggestions?
I’m actual running a real EGR block off plate on my built head.
Yesterday, I took the rear seats out again and fixed the wiring for the Walbro fuel pump. I tried to use the shrink wrap/solder connectors, but I guess I didn't get the connection hot enough as the connection was terrible. So I went back to the old fashion way, solder and shrink wrap. The connection is very good now. Next I checked plug one. The last time that I had the car running, it was pig rich, I'm talking off the gauge <9.5 AFRs rich. Plug one was completely black. I remembered that the car has been like this ever since I put in the new engine and so I have a suspicion that the coils were damaged when I took the old engine out (not to mention the fact that I purchased them used off of eBay originally). So I ordered a new set of Denso coilpacks and wires from rock auto. I also ordered a new set of NGK R5671A-8 plugs. So when those come in, I'll compete the tune up.
Today, I removed the radiator fan, and pretty much everything else to replace the front main seal. While I had the car apart, I removed the AC compressor and replaced it with my freed engineering billet AC delete bracket. I also removed the soft lines from the car. Will remove the hard lines when I replace the coilpacks and plugs sometime this week (hopefully). Next I removed the old front main seal and checked the oil pump pressure relief hole, it was clear. I am now hoping that the last two times that I installed the seal, I did something incorrectly. I applied a bit of heat to the current seal and slid it into place, applying even pressure around the whole seal using a special seal pressing tool that I 3D printed off of thingiverse. Hopefully it doesn't leak this time.
Before buttoning everything up, I took off the thermostat housing and ground the ears down on it so that I could flip it around. Doing that gave me plenty of space to hook up the turbo charge pipe! Got it all back together about 6 minutes before the sun went down
AC Delete Bracke in place
With the shorter serpentine belt in place
Charge pipe connected
Broken wire
While I was in there, I removed the condenser coil and installed a cover trim that normally covers the condenser coil, since it was missing when I purchased the car.
Trim piece
I'm thinking that I'll get my fan shroud hydro dipped... If the cost is too high, I'll just spray paint it gloss black and move on.
I decided not to hydro dip and instead to just paint gloss black the radiator shroud. I also painted the trim piece in front of the radiator with the same paint.
Here is a short video of the car running. Still a couple small things before I take it back to the tuner to get it retuned for the new turbo. What are your thoughts, will I need to retune on the CD009 transmission, or should the car be fine with that change after the tune?
I like to minimize the wiring as much as possible, so this time I tied the wires together that I could, 12v+/ground -/dimmer, and then terminated them using a R/C servo connector. I already have a servo connector receiver in the car for the current gauges. I'll just have to move the current Oil Pressure signal wire to the new wire and then connect the new pressure sender to the old manual vacuum line and connect the signal wires.
Enough talking:
I have enjoyed your thread and look forward to new coming post. I have a short question. When you installed your new Manzo cat back mufflers, did they fit the OEM hanger brackets or did you have to modify the brackets to make them look so perfect.
Thanks,
Bill
Thanks,
Bill
Im glad you’ve enjoyed my thread! The manzo mufflers were easy to install. They fit the factory hangars perfectly.
