window doesnt work...HELP!!
Old Apr 4, 2003 | 10:04 AM
lexsc3's Avatar
lexsc3
Default window doesnt work...HELP!!
my window was working perfectly fine yesterday and now i put it down and it wont go up....i can hear the window motor working but i cant figure out where the damn thing is...anyone else have this problem with there SC?
Old Apr 4, 2003 | 11:21 AM
hwallen172's Avatar
hwallen172
Yes, that happened to me. The glass shop I took it to said it was the "regulator," and it cost about $65 to fix it. One piece of advice: if you need to cover the window with plastic, be careful of the kind of tape that comes in contact with the black door pillar. I used electrical tape because that was all I had on hand, and it pulled the paint right off.
Old Apr 4, 2003 | 11:37 AM
supathug's Avatar
supathug
check the ground wire on the master switch the one that has the door locks and window controls. when i got my car my windows didn't work either and spent about 2 weeks going through everything twice and it turn out to be the ground wire. it would be a free and easy fix.
Old Apr 4, 2003 | 12:15 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
thats mechanical failure, not a ground wire.
Old Apr 4, 2003 | 02:27 PM
lexsc3's Avatar
lexsc3
yea i got the window to go up by pushing it up and now i put a peice of wood inside the door to keep the window up...ill probly get it fixed when i go home, cant trust any of the mechanics out here at school...another thing that might help to figure out what broke is that it made a big banging noise right before it went down....does anyone know how i can look at the motor and the mechanical parts in it?...ive taken off the inner-panel already and the motor is covered by a sheet metal.
Old Apr 11, 2003 | 08:58 AM
supathug's Avatar
supathug
I can also hear the motor working and by redoing the ground wire it fixed it. just telling what happen to me. the fixed was free, just trying to help.
Old Apr 16, 2003 | 10:13 PM
lexsc3's Avatar
lexsc3
i looked at the window mechanism and its the thing that connects the window to the guide rail and metal line....does anyone know what this is called?...do you know how i can get it off?, there are not bolts.
O. L. T.
Oct 29, 2022 04:31 AM
Returd
Feb 8, 2017 05:53 PM
nawarz111
Mar 1, 2014 02:50 PM
RXGS
Apr 14, 2012 09:04 AM
BostonSC4
Nov 28, 2010 05:42 PM
