Overheating problems
Old Oct 28, 2013 | 09:27 AM
PseudoK's Avatar
PseudoK
Default Overheating problems
Maybe it was cause it was cold (40 - 50 degrees out) but I changed the thermostat yesterday, and filled the whole system with water, I mean pulling hoses and dumping gallons of water in, even directly into the engine.
also bought a new radiator cap and the thermostat is a autozone generic.
also what is this?
it has broken into many pieces. and a couple times when overheated it was shot out of the hole (the center portion of this thing) with much steam coming out.
I want to get coolant in the system but not until I get this issue fixed so I am not throwing money in the trash.
either way I had heat out the heater before today, and now NOTHING my 2 hour commute was freezing. I stopped a couple times with the engine running and fed it more water.
I dont suppose my water pump went out? revving the engine I can see water fluctuating in the overflow.
I am really suprised with how long it has overheated to red and its still running great, I really dont want to have to push it anymore, specially since I just overheated and ruined my Previa van over the weekend as well, iron block and alum head and now that wont start at all I DONT WANT THAT TO HAPPEN TO MY SC400, help?
Old Oct 28, 2013 | 12:09 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
I think you just answered your own question.
That "million pieces plastic thing" is the temperature reader, somebody correct me if I'm wrong. Find a JY SC and grab that mechinism and swap it out for yours.
Old Oct 28, 2013 | 01:38 PM
PseudoK's Avatar
PseudoK
my gauge is registering a temperature though.
Old Oct 28, 2013 | 02:13 PM
estomax's Avatar
estomax
coolant level sensor. little light above the temp gauge on dash that looks like a prison window.
Old Oct 28, 2013 | 02:24 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
That explains it. Thanks for the clarification.
Old Oct 28, 2013 | 04:03 PM
CatManD3W's Avatar
CatManD3W
Did you check the oil to see if it is a coffee colored. If that is the case it may be a headgasket. Try the simple things first like new radiator cap, inspect radiator for cracks/leaks, you may also have air in the system. Good luck
Old Oct 28, 2013 | 04:34 PM
SC4ME's Avatar
SC4ME
mine was coffee colored! what does it mean, i thought it was just dirty? does a new cap really help?
Old Oct 28, 2013 | 05:13 PM
PseudoK's Avatar
PseudoK
Yea mine would be a different color than that because of royal purple lol.
but yea already new radiator cap and thermostat.
but the thing is the heat was working yesterday before I changed the thermostat.
drove all the way to work today (80 miles) with no issue of overheating, just frozen from the lack of heat.
Old Oct 28, 2013 | 07:29 PM
CatManD3W's Avatar
CatManD3W
If your oil looks like a milkshake....which would indicate you have coolant in your oil.
A new cap is only necessary if your radiator is not holding pressure
Old Oct 29, 2013 | 04:22 AM
Vrank's Avatar
Vrank
Guessing you don't know how to fill a car with water?
Old Oct 29, 2013 | 04:42 AM
SC4ME's Avatar
SC4ME
yea it does lol, not saying that i would drink it, so how do i fix this problem? thanks!
Old Oct 29, 2013 | 04:43 AM
SC4ME's Avatar
SC4ME
is royal purple even good? i never tried it.
Old Oct 29, 2013 | 06:06 PM
PseudoK's Avatar
PseudoK
SC lesson number 458: that 17MM bolt on top of the thermostat housing must be for burping the system of air, because as SOON as I opened that and revved the engine heat started coming out of my heater.
now I believe the car shouldnt overheat anymore, I have only been concerned about the lack of heat from the heater. heres hopen.
DaKi3241
Apr 12, 2013 11:56 PM
Yg_green1
GS - 1st Gen (1993-1997)
Apr 5, 2007 09:44 AM
esandes
Maintenance
14
Jun 26, 2006 11:12 PM
Xeeeeeem
May 20, 2006 01:00 PM
daveochoa
Jan 5, 2006 04:39 PM
