Over heating
Old Jan 3, 2006 | 10:23 AM
daveochoa's Avatar
daveochoa
Default Over heating
My 93 SC 400 seems to be over heating, I changed out the coolant, changed out the thermostat, bleed the system, worked fine, but after sitting a week, I started it up, noted that no heat from heating system, even on high, then after about 4 blocks, started to overheat again. I don't see any visual leaks. Please advise
Old Jan 3, 2006 | 10:26 AM
kietlander's Avatar
kietlander
when was the last time the car got a new water pump?.
Old Jan 4, 2006 | 08:52 AM
PHLSingle's Avatar
PHLSingle
All the belts ok? Bad / broken belt = water pump not pumping
Old Jan 5, 2006 | 07:56 AM
bigmalik00's Avatar
bigmalik00
funny as it may seem I started out with a non factory thermostat and I had the same problem. Please if you haven't get a Lexus(toyota) thermostat
Old Jan 5, 2006 | 03:00 PM
SupraCoup3's Avatar
SupraCoup3
heat in the car works by taking coolant and pushing it through a minature radiator, called a heater core. Lack of heat, could be lack of coolant moving.
the car overheating also points to coolant not moving.
Logical explination: Water pump isn't moving the coolant.
Old Jan 5, 2006 | 04:39 PM
ChronoJ1's Avatar
ChronoJ1
I had a similar problem.
Water pump was the culprit.
It will cost you some.
Pos300
Jun 10, 2015 06:35 AM
Patsum
Jul 27, 2012 04:29 AM
GKenns
Aug 26, 2008 11:55 AM
Colpup ES3
Dec 14, 2007 10:09 AM
esandes
Maintenance
14
Jun 26, 2006 11:12 PM
