Anyone Know What This Wire (s) Do?
Old Mar 3, 2013 | 01:45 AM
TheAzn's Avatar
TheAzn
Default Anyone Know What This Wire (s) Do?
Anyone know what the wire is for? Or could it be some custom work?
I do not want to connect these wires not know wtf they are for possibly and inadvertently turn my SC into a Lexus Charcoal. I bought the car with the wires like this, I didn't do it otherwise I would be my own personal dumbass asking you guys why I did do this for.
It's a single yellow wire, one going to each side marker light in my front bumper. But somehow it look like the driver side wire got pulled apart.
Aside from the yellow single wire, there's already two wires going to each side marker which I assume is to power the side markers. Leaving me to question wtf the yellow wire is for. BTW, in the second pic, the yellow wire has a nylon sleeve covering it.
So, before I repair the yellow wire, anyone know what it does?
The previous owner of my SC installed clear LED side markers, if they make a difference [besides appearance].
Also, if possible.... This one too. What does this wire do and/or why it would be cut.... This is the part of the wiring harness under the hood, on the passenger side, in front of the passenger strut mount. Why, what...
Old Mar 3, 2013 | 06:13 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Can you call or get in contact with the previous owner?
Maybe he was trying to find a constant or remote 12volt source in the harness????
I really dont know, jusy throwing out the possibilities?????
Old Mar 3, 2013 | 09:21 AM
TheAzn's Avatar
TheAzn
He doesn't know/ didn't reay seemed like he wanted anything to do with the car after I bought it. Still need to source out the rotors and pads so I know where to get them....
Old Mar 3, 2013 | 09:46 AM
Dx3's Avatar
Dx3
Why don't you put a multi-meter on it and see if it has power...?
Old Mar 3, 2013 | 02:11 PM
TheAzn's Avatar
TheAzn
I figured if it didn't have power, it wouldn't be cut or required to be cut... Unless you want to cut power off to something.
Old Mar 3, 2013 | 02:46 PM
xxtoobsxx's Avatar
xxtoobsxx
That pink wire you can probably connect to the other end of the pink wire. The yellow looks like he used the power of the turn signal to switch on something else. Maybe HID's for fogs, or some stupid light thing or a radar detector or something that requires switched power!
Old Mar 3, 2013 | 05:51 PM
TheAzn's Avatar
TheAzn
Do those side markers in the bumper flash with the turn signals in the headlights from factory?
I would connect the pink wire... if I know what is it for and why would someone cut it.
Old Mar 4, 2013 | 09:31 PM
TheAzn's Avatar
TheAzn
To update, after probing around, the yellow wire is running between the turn signal and the bumper side markers. Maybe the previous owner made them blink when the turn signal is engaged.... but the one side that is connected never blink....??????....
I still don't know about the pink wire and thats factory!
Old Mar 5, 2013 | 07:22 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I know when talking about speed cut people say cut the pink wire, but im not sure where they do that normally, but its probably safe to assume both ends of that wire should be connected normally. do you have a CEL, especially when you go over 60, that could be it.
Old Mar 5, 2013 | 09:08 AM
TheAzn's Avatar
TheAzn
No CEL. Speed cut, you mean like a rev limiter? If so, I hit the rev limit and it cuts power so i know it is still there.
Old Mar 5, 2013 | 09:26 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
no not the rev limiter, speed cut is your top speed limiter and stops you from accelerating past a certain mph.
normally its found on jdm swaps because their speed cut is only 110mph because of the km/h conversion, and people will cut it and/or put a switch on it to disable it.
I would think on a car with a stock 2jzge that one wouldn't be hitting the usdm speed limiter very often as its a bit higher I think, but since its cut in half and pink I figured it could be that so I would throw it out there, or someone thought it was the speed wire. I don't think its that cause its cut in the engine bay but its very odd.
LexBrett
May 19, 2015 12:02 PM
bryan767
Apr 19, 2011 10:00 AM
supra_trd
Mar 20, 2009 02:48 PM
blackbelt
Oct 24, 2006 03:44 PM
mjr24
Sep 19, 2002 12:02 AM
