Need help!!!!
Old Dec 19, 2012 | 05:23 PM
fatkhoa's Avatar
fatkhoa
Default Need help!!!!
I've been searching for the last few days and can't find a solution to my problem.
My lowbeams will only turn on when i pull on the high beam switch but won't turn on normally. The fuses and relay are fine, my wire harness was a little chewed up so i re-did the wires that were damage but still my lowbeams won't turn on...
what else can be the problem???
Posted from ClubLexus.com App for Android
Old Dec 19, 2012 | 05:36 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
If everything else checks out, I was look into checking the actual switch itself. Tho I have never heard of one on here going bad...
Old Dec 19, 2012 | 07:46 PM
fatkhoa's Avatar
fatkhoa
i tried using a working switch but still not working
Old Dec 19, 2012 | 07:55 PM
OG Dada's Avatar
OG Dada
Check and recheck the wiring. It could've gotten pulled so the problem is not just where you redid it.
Old Dec 19, 2012 | 07:57 PM
Chris88's Avatar
Chris88
Not sure if your SC400 would be the same as my JDM Soarer TT but if it is you could try changing out the headlamp relay in the dome fusebox under the hood by the battery.
Old Dec 19, 2012 | 11:05 PM
fatkhoa's Avatar
fatkhoa
this is driving me crazy... i changed the relay and still not working......what is going on??
Old Dec 20, 2012 | 12:12 AM
xxtoobsxx's Avatar
xxtoobsxx
you have aftermarket hids on the car?
Old Dec 20, 2012 | 07:08 AM
fatkhoa's Avatar
fatkhoa
yes i do
solefresh8
Jan 14, 2017 07:39 AM
Br4den
Jul 2, 2016 09:55 PM
Moose0185
GX - 1st Gen (2003-2009)
Mar 5, 2015 10:34 AM
awj
Aug 4, 2002 05:23 PM
