Lsd options for a street SC?
Old Nov 13, 2012 | 01:20 PM
xspsi6's Avatar
xspsi6
Default Lsd options for a street SC?
This
http://www.ebay.com/itm/Kaaz-SAT3030...086487&vxp=mtr
Or this
http://www.ebay.com/itm/93-98-Toyota...d42247&vxp=mtr
I really do not want a torsen as tey are way to pricey and I may as well just opt for one of these units, I s there any options I am leaving out?
I think Kaaz is the same as the TRD unit if I am not confusing my facts here?
Old Nov 13, 2012 | 03:43 PM
maynanator's Avatar
maynanator
for street use i would say get a 1.5 not a 2.0 lsd. I think the 2.0 would be a little too agressive; 2.0 is more meant for drifting or track use. besides that I couldn't really tell you which one to go with. I have heard some hearsay that the kaaz is the way to go. Good luck.
Old Nov 14, 2012 | 08:53 AM
spoolxexo's Avatar
spoolxexo
Welded/Spool means Full lock on both acceleration and deceleration.
A 2-way diff means it's locking (Mostly) both on acceleration and deceleration.
1.5-way means Most lock on acceleration and moderate locking on deceleration.
1-way Or Torsen type means it will lock on acceleration and open up on deceleration.
Sudden un-locking of the diff will make the car jerky in mid-slide situations, but allows you to turn into Taco Bell easy.
Constant Locking of the diff makes the car easy to control when sliding, but makes the tires chirp and wear when low speed cornering.
Get a 1.5 Clutch type!
Old Nov 14, 2012 | 09:04 AM
xspsi6's Avatar
xspsi6
Yea clutch type is what I am looking for but what are some good options for this?
Old Nov 14, 2012 | 09:17 AM
spoolxexo's Avatar
spoolxexo
Well, I'm a cheap bastard from all the DSM's I owned so I am hammer-fisting a MKIII LSD into mine but...
All options are good. No one can afford them, which is why you see a lot of "Bolt-in" Narrow G-code SC/Supra 8" diffs.
KAAZ, CUSCO, TRD They all rock.
Just find a clutch type and specify how much "Lock" 0-100 you want based on the type of driving.
70-90% lock is used in competitive drifting, and 30-65% is used for overall/circuit/grip type driving.
If I had the loot this is my pick: Cusco LSD 168 L15 - 1.5 way JZA80 Supra
Old Nov 14, 2012 | 09:54 AM
xspsi6's Avatar
xspsi6
Haha I have owned 12 awd DSM's and 5 evo's so I know this all to well.
No drifting for me just maybe a few track days per year and that's a big maybe but the one tire fire is not acceptable!
Old Nov 14, 2012 | 01:14 PM
megamax's Avatar
megamax
so, more on this "fisting"project of yours please!!
Old Nov 14, 2012 | 01:55 PM
nlc's Avatar
nlc
X2 ive been following the build but you dont have info in how ur doing it..are u jus switching the pumkin or the whole unit itself?
Btw lol @you fisting your rear end...doubt thats a easy task.
Old Nov 14, 2012 | 02:29 PM
spoolxexo's Avatar
spoolxexo
The whole thing is going to be mounted, MKIII Supra axles fit on paper, so I have to confirm that too.
Then an adapter to make the MKIII pumpkin bolt up to the sc300 driveshaft.
Old Nov 14, 2012 | 04:05 PM
xspsi6's Avatar
xspsi6
Sothe mk3 lsd unit will ot bolt up t the SC ring gear?^^
Old Nov 15, 2012 | 04:22 AM
spoolxexo's Avatar
spoolxexo
No. The entire mkiii pumpkin has to be mounted in.
crowstyle
Jun 10, 2016 09:05 PM
Kharizma
Performance
Feb 20, 2007 01:37 AM
Cannonbear
Performance
19
Jan 24, 2005 03:44 AM
laxdude362
Jan 12, 2005 09:38 PM
