Tail Lamp Failure Sensor - Resistor Value
Old Dec 3, 2002 | 03:41 PM
95SC400's Avatar
95SC400
Default Tail Lamp Failure Sensor - Resistor Value
After performing a conversion from '95 to '97+ tail lights, the tail light failure sensor comes on because, as has been discussed before, there are fewer bulbs.
I opened up the tail lamp failure sensor and this truly is an easy fix. There are 3 resistors that are set up on easy to get to jumpers, away from the circuit board.
Is there anyone with a '97+ who might be willing to pop open their sensor and supply the color codes/value of the resistors?
This would be great info for anyone wanting to avoid spending $150 for a new sensor which is literally made up of $3.00 worth of parts.
The sensor is located on the driver's side, in the trunk. It is a 2" x2" black box and is easily popped off from a vertical support, after removing the trim with the med kit. Run your hand on the inner side of the support and you should find it.
Unplug it and use a small screwdriver or something to pry it open, it has no screws.
Let me know if anyone needs any other info on upgrading to 97+
Old Dec 3, 2002 | 03:50 PM
AutoCoutureSC's Avatar
AutoCoutureSC
Post
i was looking into this for a while, but are you talking about the flasher relay or the actual circuit board?
Old Dec 3, 2002 | 03:56 PM
95SC400's Avatar
95SC400
This is in regards to the actual circuit board, which makes up the failure sensor.
The flasher relay does not need to be changed in this case because it is from a '95 to '97+ and both had only one turn signal bulb per side. Unlike the '92 to '94 which had more... 3 i believe.
BTW... The '97+ has 1 less brake light bulb and 1 less running light bulb per side than the '95 to '96.
Thanks...
Old Jun 26, 2004 | 10:00 PM
Bryan858's Avatar
Bryan858
Default Any new???
Just curious if any one found a fix... I have a 92 so I don't think my resistor values will help any... Do you have a 95? Hmm, maybe I can compare mine with your and see if there is a difference... Bryan
kongvang1
RX - 1st Gen (1999-2003)
Dec 16, 2018 06:40 PM
CrazySC300
Sep 14, 2011 01:47 PM
trickedout
Mar 31, 2011 04:39 PM
Vortes
Jun 21, 2009 01:18 AM
niceSC
Oct 31, 2006 05:16 AM
