Wiring in gauges...?
Not finding what I'm looking for and I'm having a hard time finding the correct wires to wire my gauges to.
I am mounting my wideband and boost gauge to the dash. I have the wires from the gauges going into the climate control/radio area. What wires should I be or can I wire into?
So far I've only gotten my wideband put in and the diagram I pulled from the internet was no help. The gauge lights up, but it's on all the time.. Doesn't matter if the key is in or not.... I tapped into the blue/yellow wire from my radio... Then tried the gray one and the same thing happened.
Which wire can I tap into or what is the best route?
Shane
Shane
I would run a seperate relay from a ignition on only fuse in the driver side kick panel. Make sure to wire in a inline fuse of around 10 amps for the wideband. Ground it to a screw in there as well. This is what i did, and it works flawless. I do know the first fuse on top row closet to the firewall is a switched one. This is the one I used. GL
Shane.
PS. 1992Lexus, I FINALLY submitted feedback for you lol.
I ended up getting 2 individual dash pods that you adhere with the little 3M sticky patches. Not exactly the best look for a sleeper but oh well.. I didn't really want to tear anything else apart to hide them.
Shane
Shane
1UZFE4ME
Mar 19, 2013 06:59 PM
