Passenger side window/lock problem
Old Aug 24, 2012 | 04:53 PM
Tommy2JZ's Avatar
Tommy2JZ
Default Passenger side window/lock problem
ok two things, driving my car out of work rolled by windows down,. parked at the bank rolled them up then down. parked at home windows wont go up. i check for noises no noise when i press the up buttom on either side. there is only like a little click when i press down on the passanger side. i think its not the regulator because that means i should be able to move the window ?
next i found 2 unplugged harnesses. they lead from the window switch on the passanger side to the tip of the door near the very tip of the door farthest from the hinge. anyone know where these go? pictures would help..
95' SC300
Old Aug 27, 2012 | 08:34 AM
SCgonecray's Avatar
SCgonecray
If you could post a picture I can probably figure that out for ya. lol
Old Aug 27, 2012 | 11:50 AM
ksrnumber1's Avatar
ksrnumber1
Also what color are the harness plugs?
Old Aug 27, 2012 | 09:56 PM
Tommy2JZ's Avatar
Tommy2JZ
harnesses are gray and white, white being smaller then the gray i believe, also i broke the regulator and pushed my window up manually to get it to close, the window has capability of going down but not up, idk why lol
i looked for harnesses for the white and gray but couldnt find anywhere to connect them my guess is they were cut =(
Old Aug 28, 2012 | 05:13 AM
menty's Avatar
menty
Can the drivers side control it
Old Aug 28, 2012 | 01:03 PM
Tommy2JZ's Avatar
Tommy2JZ
No sir neither does
Old Sep 23, 2012 | 10:46 PM
Tommy2JZ's Avatar
Tommy2JZ
check this out guys! two harnesses were disconnected went to the junkyard and got them and reconnected them
disconnected...
connected
okay so this lets me now unlock the driver door by turning the key on the passanger door. lets me control door lock on passanger side with both switches.
got a new motor for my window, it goes down but not up just as my current one. ?! wtfudge is going on?!?!?!
tradosauru
Mar 4, 2016 12:11 PM
ACold
RX - 3rd Gen (2010-2015)
16
Apr 5, 2012 03:01 PM
huerdo623
Nov 15, 2007 08:54 AM
hellasboy
Maintenance
Jun 13, 2004 01:15 PM
