A/C Unit not powering up.
Old Aug 7, 2012 | 08:46 AM
empera's Avatar
empera
Default A/C Unit not powering up.
My ac unit isnt turning on...i tried another and had the same results. I also checked the fuses and non seem to be blown. I swapped out the interior a while back and it might have something to do with that. I have these two connectors that im not sure of where they go.
any ideas?
Old Aug 7, 2012 | 02:27 PM
StiCk3's Avatar
StiCk3
those two look like the ones that hook up either to the back of the unit or to the connectors in the dash directly behind the A/C unit. Where did you pull those plugs from?
Old Aug 8, 2012 | 07:07 PM
SC400DAVE's Avatar
SC400DAVE
OK this is my first time trying to upload some pics so here goes. Top 3 pick are the plugs for the back of the Radio. The last one is for the back of the climate. Luckily I had this apart still.
Attached Thumbnails A/C Unit not powering up.-dscn0017.jpg   A/C Unit not powering up.-dscn0019.jpg   A/C Unit not powering up.-dscn0018.jpg   A/C Unit not powering up.-dscn0020.jpg
Old Aug 9, 2012 | 06:01 AM
empera's Avatar
empera
hmmm i have 2 blue plugs?? i'll take more pictures today....
Old Aug 9, 2012 | 10:32 AM
GotRiceYo's Avatar
GotRiceYo
Have you checked your relays possibly??
Old Aug 9, 2012 | 11:41 AM
SC400DAVE's Avatar
SC400DAVE
That would be helpful. What year and model SC do you have?
Old Aug 9, 2012 | 12:34 PM
soarer13oy's Avatar
soarer13oy
There is two connectors right on top of the climate control when you put it back in. Does your climate control power on?
Old Aug 9, 2012 | 01:46 PM
93MSB's Avatar
93MSB
im swith stick3, the pic in your first post looks like the two plugs that are attached to the dash/blower assembly directly behind the a/c control unit/radio
Old Aug 9, 2012 | 02:57 PM
sayayin's Avatar
sayayin
on my car, the fuse box on the driver side, I forgot the fuse number, is the one that give me problems, is not blown but it make but contact, i usually take it out push it real tight again, on the plugs on the ac controller I forgot wich plug, the color green cables, they always have constant power, just check with a voltimeter, i will try for look for diagram or pictures.
Old Aug 10, 2012 | 07:22 AM
empera's Avatar
empera
its a 1992
It does not power on. Where exactly do those two connectors go?
If anyone has a picture of the female part, that would probably be the best bet.
I know the radio doesnt belong but i dont think the radio needs to be connected for the climate control to work?
Im pretty sure the issue is with those two plugs (white/blue)
Old Aug 10, 2012 | 08:23 AM
empera's Avatar
empera
Awesome, found a picture thanks to raines thread! Thanks for pointing me in the right direction guys!
Hopefully this will solve the issue. If not i will report back.
Old Aug 10, 2012 | 12:20 PM
SC400DAVE's Avatar
SC400DAVE
This is the back side of the OEM climate control and connectors for a 1992 Lexus SC400
Attached Thumbnails A/C Unit not powering up.-dscn0020.jpg
Old Aug 10, 2012 | 02:38 PM
StiCk3's Avatar
StiCk3
Those are the plugs, im 100% sure of it. I just got through diag work for my SC and was working with those plugs for a/c wiring. Should get you up and running
Old Aug 13, 2012 | 07:28 PM
empera's Avatar
empera
yep thats the one!! thanks guys! AC is working woohoo...
now im not sure on the radio...could i just get a harness adapter and make it work? i dont think the car came with an amp? but i may be wrong...
Lin182
Sep 6, 2018 02:14 PM
keelow3
Apr 8, 2018 12:33 PM
SC & LS 40
Jul 31, 2014 02:12 PM
python
Aug 16, 2012 05:44 AM
Pagong
13
Jul 31, 2004 09:54 AM
