Trans Flush? used seach multiple answers...
Mar 17, 2012 | 12:27 PM
1997 Sc400 Stock.
Shifts fine and stuff.
But the trans fluid is lightly brown, a cross between red and brown.
Car has 170k but well maintained.
Some people say to change it, some people say don't?
Anyone actually done this on a high milage SC and had good results?
Mar 17, 2012 | 12:33 PM
Drain and fill, then repeat at your next oil change.
Mar 17, 2012 | 12:43 PM
I've done it on a 180k tranny because it started slipping. As Kalogerus mention, just drain and refill dont completely flush.
Mar 17, 2012 | 12:55 PM
I'm confused, so when I pull the plug at the trans pan * there is a plug right?* I just let it drain out till it stops then fill it up and call it a day?
Mar 17, 2012 | 01:26 PM
Pretty much, cause there will still be fluid in the pan.
Mar 17, 2012 | 01:28 PM
This is the proper forum for these questions.
Moved.
Plug/bolt, should be a 14mm If I am correct. Make sure your using OEM fluid cause iz the best. Fill up where the dipstick is at.
Mar 17, 2012 | 01:43 PM
Quote:
Originally Posted by
sc300jz
Engine fan fluid container uses tranny fluid. Does it go to tranny or is it something else?
Mar 17, 2012 | 01:51 PM
Kalogerus
So does the power steering res.
Fill the trans back up Via it's dipstick. Fill it up to 3 quarts, start it, let it warm up, check level, add more if needed.
Mar 17, 2012 | 02:12 PM
Alright thanks guys, Hopefully the local Toyota has the fluid, as the nearest Lexus is mighty far away. Let you guys know sometime next week hopefully. Funds are low.
Mar 17, 2012 | 02:50 PM
lexslexus
Mar 30, 2018 01:56 PM
carguy07
RX - 1st Gen (1999-2003)
12
Jan 11, 2008 08:40 PM
lx470man
Maintenance
22
Nov 15, 2004 10:48 PM
bmoon_007
GS - 1st Gen (1993-1997)
Sep 27, 2004 01:33 PM
DK Audio
Apr 14, 2003 08:10 AM
