cluster trouble help...
Old Mar 3, 2012 | 07:33 PM
bighead222's Avatar
bighead222
Default cluster trouble help...
So I got a sc with a bhg and the therosta went all the way up to h I did a motor swap and the cluster is still all the way up right when I turn the car on but its not stuck cause it gose down when the cars off what could it be what should I look for and what can I do thks I app the help..
Old Mar 3, 2012 | 07:39 PM
Kalogerus's Avatar
Kalogerus
What? I think you should quit with the shortcuts.
From what I get so far is the needle needs re positioning. Other than that I dont know what ur saying.
Old Mar 3, 2012 | 07:57 PM
bighead222's Avatar
bighead222
How would I reposition them? basically what I'm saying the car goes to hot right when I turn it over and its definitely not hot
Old Mar 3, 2012 | 07:58 PM
BenStoked's Avatar
BenStoked
CL Folding 1,000,000
yeah, it's a little difficult to understand what you're saying.
Did you replace the water temp sensor on the new motor?
Old Mar 3, 2012 | 08:04 PM
Kalogerus's Avatar
Kalogerus
In that case I dont think its ur cluster. Its something under the hood.
Old Mar 3, 2012 | 08:09 PM
bighead222's Avatar
bighead222
Didnt replace the sensor its a new motor and I changed the water pump and thermostat. what would I
wanna,look for under the hood?
Old Mar 3, 2012 | 08:25 PM
MooJohn's Avatar
MooJohn
Unplug the temp sender under the hood and see if the gauge still goes up. If it does, it's the gauge.
If it doesn't test the resistance of the sender when the car is at normal operating temp to see if it's within spec.
Old Mar 3, 2012 | 08:29 PM
bighead222's Avatar
bighead222
Thks man ill give it a shot and see what happens.
etcortez
IS - 1st Gen (2001-2005)
Aug 8, 2013 05:16 PM
Superjatt
Feb 26, 2011 11:29 PM
aceboogie6
GS - 1st Gen (1993-1997)
Nov 5, 2010 04:29 PM
hershsc400
Jul 29, 2008 08:46 PM
soarer13oy
Jun 24, 2008 01:04 AM
