Vibration when take off+quick pull (VID inside)
Old Nov 20, 2011 | 04:09 PM
SC300_704's Avatar
SC300_704
Default Vibration when take off+quick pull (VID inside) UPDATE!!
been having this vibration issue for awhile now but finally have time to make a quick vid of it. you can see the camera vibrating like crazy to. anyone ever had this vibrating problem before?
http://www.youtube.com/watch?v=qI5XybpGzao
Old Nov 20, 2011 | 04:25 PM
Tabaka's Avatar
Tabaka
Is the vibration all the time or only at a lower speed?
I found out what my vibration issue was. My e-brake has been screwed up and the brake shoes are pressed on the inside of my rear passenger rotor.
Old Nov 20, 2011 | 04:29 PM
SC300_704's Avatar
SC300_704
only at low speeds, around 15-25 mph.
Old Nov 20, 2011 | 04:33 PM
Luxor's Avatar
Luxor
The only things I can think of is that the clutch may not be aligned, or flywheel warped. Or something as simple as the transmission mount being busted.
Old Nov 20, 2011 | 04:39 PM
SC300_704's Avatar
SC300_704
i've been meaning to buy a new transmission and engine mounts but never did. that's definitely next on my to buy list.
Old Nov 20, 2011 | 07:32 PM
antonio356's Avatar
antonio356
Check the driveshaft isolator. That the rubber thing between the end of the drive shaft and the diff...
Does it vibrate more the faster you go?
Old Nov 20, 2011 | 08:41 PM
chingpo05's Avatar
chingpo05
does it shake if you keep that speed constant? while wheel is straight and turned? and foot still on clutch while releasing and shaking at same time? while youre at it check all mounts including rear diff one.
Old Nov 20, 2011 | 09:05 PM
SC300_704's Avatar
SC300_704
yeah i was thinking it could be that, even bought a used one but found out it has more rips in it than mines.
Old Nov 20, 2011 | 09:08 PM
SC300_704's Avatar
SC300_704
it vibrates whether i'm going straight or turning like in the vid but don't remember if i ever tried staying at the same speed or stepping on the clutch while it's vibrating. i'll try it out tomorrow.
Old Nov 20, 2011 | 10:21 PM
CantSeeMe's Avatar
CantSeeMe
Does it do that at idle at all? Perhaps engine or tranny mounts.....
Old Nov 20, 2011 | 10:26 PM
SC300_704's Avatar
SC300_704
No it doesnt do that on idle but could possibly be the mounts since I had never changed it before.
Old Nov 20, 2011 | 10:34 PM
Toyboxx's Avatar
Toyboxx
Same thing was happening to me on my GSX, sounds like a carrier bearing or something that has to do with the driveshaft.
Old Nov 20, 2011 | 10:38 PM
k7q's Avatar
k7q
axle? i know its rare for axles to go back in rwd but it happens
Old Nov 21, 2011 | 06:27 AM
stockhatch's Avatar
stockhatch
So your isolator is ripped up and you have never changed mounts? No wonder it has the DTs. Replace those parts and you should be good to go Your car sounds awesome BTW.
Old Nov 21, 2011 | 07:02 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
All of the above information could be the possibility.
