1jzgte twin to single conversion - coolant lines
i just wanna see what people are doing for these few coolant lines. i looped the one by the upper water neck. but these other 3 im not sure what to do. i may just end up putting a bolt in one of them and looping the other 2 that are next to each other
two that are next to each other:
one by its self:
one by its self:
This is what I ended up doing. One of the water neck ports I plugged and made the return the lower one. See pics I left the heater hooked up and pluged the one closest to the downpipe. Hope this helps
Also check outs Biggus build, it helped me out
https://www.clublexus.com/forums/per...ld-thread.html
where did you find the rubber cap for your water neck?
canucklehe
Nov 22, 2013 07:46 PM
