help please
Old Apr 3, 2011 | 08:10 PM
BAD954BOI's Avatar
BAD954BOI
Default help please
hey guys as you can see by the title i need a favor...
i recently replaced the GE motor in my sc300 and after working out the puzzle i came across with the water return lines i found oil being mixed into the water lines... i think i may have connected a hose in the wrong place or just installed the head gasket wrong or probably did both...
so after searching the forms for a diagram for the water return line diagram i came up with nothing so if someone could post a link or a break down of what hose goes where or could post up pictures it would be kindly appreciated
Old Apr 4, 2011 | 05:45 AM
99SC42's Avatar
99SC42
The head gasket goes one way, i don't think it's the Hg.
Old Apr 4, 2011 | 07:26 AM
addisonblc's Avatar
addisonblc
http://www.lexuspartsnow.com/diagram...et-160092e.png
link to a diagram of the main water lines.
hope it helps
Old Apr 4, 2011 | 09:05 PM
BAD954BOI's Avatar
BAD954BOI
damn i think i figured out where i possibly messed up...
now i need to figure out where the hose that connects to the the back of the clyinder head directly centered in between the valve covers goes cause i plugged it here: on the bigger fitting to be exact
Old May 22, 2011 | 10:49 AM
BAD954BOI's Avatar
BAD954BOI
thanks to my boy (Gezup)
for coming through and letting my use his car as a live diagram
Old May 22, 2011 | 11:06 AM
good2go's Avatar
good2go
I hope you're planning a full flush/replacement of the coolant, motor oil, and oil filter after this.
mavs2001
IS - 1st Gen (2001-2005)
Sep 20, 2012 12:41 PM
bryanc182
Maintenance
Oct 6, 2011 07:25 PM
BAD954BOI
Florida Lexus Club
Apr 3, 2011 09:22 PM
kaidoy
Mar 9, 2008 05:24 PM
MikeysSC
Sep 5, 2002 05:28 PM
