Temp Gauge in the Red
Old Dec 8, 2010 | 09:27 PM
Nolamatt's Avatar
Nolamatt
Default Temp Gauge in the Red
Temp gauge in the red. Ok so this is my second sc300. So, I am not stranger to the car. However, I am a stranger to this problem. So I changed out the radiator which was filthy and need to be changed anyway. The fan clutch was out, changed that. Replaced the thermostat. Meter is still reading in the red! Why is this happening?! I've been assured by a mechanic that the car is not actually over heating. Anyone have this problem or have had this problem?! Than you!
Old Dec 8, 2010 | 09:30 PM
chingpo05's Avatar
chingpo05
blown head gasket maybe. any oil in the coolant or vise versa? maybe just a bad temp sensor
Old Dec 8, 2010 | 09:34 PM
Nolamatt's Avatar
Nolamatt
Guess i`ll have to do a block test lol
Old Dec 8, 2010 | 10:45 PM
turbodremz's Avatar
turbodremz
Any steam coming from the engine? Water in the oil? Milky oil? Rotten egg smell after car is at operating temp? Steam/smoke from the tail-pipe? If so, what color? Has it been like that since you got the car? Cluster ever been removed or tampered with?
A bad temp sensor wont register on the gauge, it will simply stay at its lowest point. There are several questions that need to be answered before jumping to a blown headgasket, not to mention the sensory side effects associated with a BHG (i.e.-smells, seeing steam/smoke, hearing the car running on a dead cylinder, etc.).
Old Dec 9, 2010 | 06:32 AM
Nolamatt's Avatar
Nolamatt
No steam. No egg smell. No smoke coming out tail pipe. No water in oil. No milky oil. No smoke. It has been doing it since I purchased the vehicle. The cluster has been tampered with. Not while in my possession. Only reason I know so is because the clips at the top of the cluster are gone lol.
Old Dec 9, 2010 | 07:06 AM
jdmsfl305's Avatar
jdmsfl305
when you installed the new radiator did you bleed the coolant system?
Old Dec 9, 2010 | 07:11 AM
Nolamatt's Avatar
Nolamatt
Yes I did.
Old Dec 9, 2010 | 07:40 AM
Tabaka's Avatar
Tabaka
Well if the car is definitely "not overheating" in technical terms, then there is an issue with the gauge. Do you have a buddy that you can swap the gauges with just to check? Unfortunately this is going to be a process of elimination.
Old Dec 9, 2010 | 10:28 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
I would guess that maybe the gauge needs to be fixed if the car isn't actually overheating.
Old Dec 9, 2010 | 11:28 AM
Nolamatt's Avatar
Nolamatt
Sadly, after hurricane Katrina, sc's are hard to come by in new orleans. So I wouldn't be able to have access to one temporarily. What a nightmare!
Old Dec 9, 2010 | 11:41 AM
turbodremz's Avatar
turbodremz
^^That right there. I would be willing to bet money that when it was removed, the needle was moved by hand. I would say there is a 99% chance you have nothing to worry about except how to set the needle back to where it should be.
Old Dec 10, 2010 | 12:13 PM
Nolamatt's Avatar
Nolamatt
Thank you turbo! Any advice anyone can tell me about taking the cluster out? Never messed with it before
Old Dec 10, 2010 | 12:59 PM
scforlife's Avatar
scforlife
Does the upper radiator hose feel hot while the car is running? My car wasnt cycling antifreeze through the upper hose so it was overheating. Just throwing ideas out.
Old Dec 10, 2010 | 01:07 PM
turbodremz's Avatar
turbodremz
Best I can do for that one is:
https://www.clublexus.com/forums/sc-...-lighting.html
https://www.clublexus.com/forums/sc-...d-threads.html
First link tells you how to remove the cluster, but not pics. Second link is just a few links to every DIY you would ever need and more.
Old Dec 11, 2010 | 12:37 AM
Nolamatt's Avatar
Nolamatt
Thank you! I'll go over those links, and let everyone know how it came out! Thank you again CL...(and turbo)
jennypenny
Apr 3, 2019 10:30 PM
FUZCO
RC - 1st Gen (2015-present)
Nov 17, 2015 05:59 PM
MValentine
Sep 7, 2013 02:10 AM
Vishuz
Nov 29, 2011 06:02 AM
salimshah
RX - 1st Gen (1999-2003)
Feb 9, 2007 01:27 PM
