problems after problems.
Old Oct 16, 2010 | 06:07 PM
sc300619's Avatar
sc300619
Default problems after problems.
well this is my 1 post. sorry if its in the wrong section. but ok. i recently locked my keys in the trunk, and i need them out. the electronic lever under the steering wheel will not work and i have been doin some research. some thing about "if you unlock the key" it will work well mine is pushed in, i want to know if there are any other ways of getting to the trunk. taking off back seats, some mechanical lever somewhere??
Old Oct 16, 2010 | 06:28 PM
sc300619's Avatar
sc300619
soo noone can help me
Old Oct 16, 2010 | 06:39 PM
ASTERiSK's Avatar
ASTERiSK
I locked my keys in the car once too (pretty hot day when I was conditioning my seats). I had to ask my brother if I could use his AAA service, I called them and they said they sent a tow truck on the way. The tow truck driver came out with an air wedge (Pumps air between the crack of the door) then they stuck a wire in to press the door lock switch, they expected a security system to lock it again immediately so they pulled the handle quickly, but it was alright. From there I'm guessing you can pop open the trunk from the lever in the car on the driver's side. I would try and call a tow truck near you if you can't find anyone with AAA service.
Hope I was of some assistance.
Old Oct 16, 2010 | 06:48 PM
ASTERiSK's Avatar
ASTERiSK
Whoops, never mind that. I'm sure this has happened before though, I read some posts saying that it's easier going through the trunk. Hope you get through this, I strongly suggest people to get spares :P. That would save you so much trouble...
Old Oct 16, 2010 | 06:49 PM
abounly's Avatar
abounly
i remember reading that someone had a problem like this, where your trunk lock button is there is a little clip behind it you flick it and it should work i believe.. its been awhile
https://www.clublexus.com/forums/sc-...aster-key.html
searching is your friend
Old Oct 16, 2010 | 06:50 PM
durtysc300's Avatar
durtysc300
i removed the back seats and the speakers and found mine after about 8 hours with a wire hanger..
Old Oct 16, 2010 | 08:52 PM
Sc4Jr24's Avatar
Sc4Jr24
give lexus dealer ur vin,reg, and $80 bucks.
Old Oct 16, 2010 | 09:13 PM
scviolence's Avatar
scviolence
damn another one ive posted this **** like 5 times lol...drop the panel where the electronic trunk switch is...there are 2 plugs to that switch one of the two plugs has 2 wires one black, and one blue....pull that one...take a paperclip or wire and short that plug out(touch one side to the blue wire and one side to the black at the same time) your trunk should pop open and you can get your keys easy day....good luck hope this works....lemme know pm or whatever if it still wont open.....update us....
Old Oct 16, 2010 | 09:41 PM
sc300619's Avatar
sc300619
sweet, thank you all i will try tomorrow morning, much appreciated.
Old Oct 16, 2010 | 09:52 PM
King7Two's Avatar
King7Two
CL Folding 200,000
How the FFFFUUUUUUU did you do that?
How did you get around the gas tank?
Old Oct 17, 2010 | 01:38 PM
sc300619's Avatar
sc300619
thank you man i got it open. appreciate it.
Old Oct 17, 2010 | 02:10 PM
scviolence's Avatar
scviolence
lol your welcome
Crisjonson
Aug 27, 2018 07:51 PM
jeffnguyen
Mar 22, 2014 07:04 PM
REDRAIDER
Feb 19, 2011 12:58 PM
SilentWish
Aug 27, 2010 11:21 AM
jmoney1698
May 22, 2008 11:56 AM
