o2 sensor compatibility range
Old Apr 9, 2010 | 01:02 PM
ashtray's Avatar
ashtray
Default o2 sensor compatibility range
Updated Question
Is there a way to make 4 wire threaded o2 sensors from a 1997 SC300 fit into a header that has bolt on o2 sensor bungs? Thank you.
Will o2 sensors from a 1995 and older sc300 work with an OBDII ecu and plug from a 1997 and up o2 sensor? Thanks
yarthsA
edit: I realize they are bolt on o2 sensors..but will the plugs work? and will the ecu read it correctly and all that?
Old Apr 9, 2010 | 06:48 PM
ashtray's Avatar
ashtray
Some one please. This cant be that hard a question. I searched and nada.
Old Apr 9, 2010 | 07:38 PM
1siksc's Avatar
1siksc
Hi! Sry I should of checked this section earlier. It all depends on the number of wires the one you have on now is. When I was N/A i picked up 2 borg warner o2's from ebay dirt cheap Brand New and they had the same amount of wires running out of them.
Old Apr 9, 2010 | 08:37 PM
ashtray's Avatar
ashtray
So the dependent factors are the wires. I know the ones my car had(which i cant use with this new manifold) had 4 wires. I am assuming the 1995 SC300's have 2? Do they make 4 wire bolt on o2 sensors? Thanks for chiming in. Appreciate it.
yarthsa-
Old Apr 11, 2010 | 11:56 AM
ashtray's Avatar
ashtray
bump to see if anyone can have another look into this.
Old Apr 11, 2010 | 12:46 PM
99SC42's Avatar
99SC42
If you can plug it up it should work.
Old Apr 11, 2010 | 07:36 PM
1siksc's Avatar
1siksc
what manifold are you using? I am making this a link on my browser now sry for the late response again.
Old Apr 11, 2010 | 07:38 PM
1siksc's Avatar
1siksc
wait... manifold? you na-t? thats probably a screw in for wideband 02 and the stock goes on dp. I know the Borg Warner o2's I had were screw ins.
Old Apr 11, 2010 | 07:40 PM
1siksc's Avatar
1siksc
this work? http://cgi.ebay.com/ebaymotors/New-B...Q5fAccessories
Old Apr 11, 2010 | 08:00 PM
ashtray's Avatar
ashtray
All of this is in reference to NA. Not NA-T.
Old Apr 12, 2010 | 04:28 AM
1siksc's Avatar
1siksc
alright, whats the manifold look like?
If it looks like the old o2 it should work. if not this place sells the stock the cheapest. You just need to wire it together. http://www.rockauto.com/catalog/rafr...1187603k870692
Old Apr 12, 2010 | 05:55 AM
Dx3's Avatar
Dx3
FYI - I know the 96 SC300 had 2-wire O2 sensors and the 99 SC300 has 4-wire O2 sensors...
Jonny
Old Apr 12, 2010 | 06:03 PM
ashtray's Avatar
ashtray
Mine are four...im sure the ones im getting are 2.
Old Apr 12, 2010 | 06:47 PM
vangb2's Avatar
vangb2
4 Wires are typically in this order:
Black wire- Ground for Heater
Black wire- Ground for body
Red wire- Heater (B+)
White wire- signal wire (0-1v only)
Old Apr 14, 2010 | 12:32 PM
ashtray's Avatar
ashtray
bump! updated question in first post.
