can this be done or is it worth doing?
Old Apr 5, 2010 | 02:38 PM
kpkim01's Avatar
kpkim01
Default can this be done or is it worth doing?
can i just swap out the old amp for an aftermarket one?
and would it really make a difference?
Old Apr 5, 2010 | 02:42 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Its like night and day difference. I sold my working old amp and replaced it with a new one. I did reuse the factory speaker wiring, but all the other needs to ran from the battery. If you need the factory wiring diagram to do this, or tap in to the factory wiring, PM me. I have it. I would also recommend changing out all the speakers or upgrade to 6 1/2 in the front and 6x9's in the rear. Throw the factory sub in the garbage or save it for a huge paper weight. Use another type of sub! JMO
Old Apr 5, 2010 | 02:43 PM
kpkim01's Avatar
kpkim01
would it work with the stock radio though?
Old Apr 5, 2010 | 02:45 PM
scviolence's Avatar
scviolence
pretty sure if you wanted to keep the factoy sub and add one also you could also use a line out converter..
Old Apr 5, 2010 | 02:50 PM
718murdoc's Avatar
718murdoc
What aftermarket amp did you have in mind ?
Old Apr 5, 2010 | 02:51 PM
kpkim01's Avatar
kpkim01
i actually didnt start looking yet. i just wanted to know if it could be done before anything
Old Apr 16, 2010 | 06:05 PM
kpkim01's Avatar
kpkim01
so im going to attempt at wiring my subs next week and i juts have some question.
1.can i use the existing sub woofer wire that goes to the head unit after i disconnect it from the stock amp?
2.how do i wire a line output converter for my new sub woofer/amp?
3.do i have to remove my radio to wire anything?
helps is greatly appreciated. thanks
Old Apr 16, 2010 | 06:06 PM
kpkim01's Avatar
kpkim01
i was going to use this LOC
http://www.walmart.com/ip/Scosche-Ad...Watts/10756155
Old Apr 16, 2010 | 06:27 PM
Scotty's Avatar
Scotty
Are you planning on leaving the stock amp in the vehicle to grab signal for the line-out converter? You'd need three of those scosche line-out converters for front/rear/sub or you could use this Audio Control LC6 for all channels.
Old Apr 16, 2010 | 07:07 PM
kpkim01's Avatar
kpkim01
im planning on keeping the stock amp for the front/rear speakers. and i was planning on using the LOC for the new amp and sub.
Old Apr 16, 2010 | 07:08 PM
kpkim01's Avatar
kpkim01
and again. i can do pretty much most of the wiring in the back of the car other than the 12v to the battery right?
Old Apr 16, 2010 | 07:17 PM
Scotty's Avatar
Scotty
Whoops... Sorry misread your post. You are correct all wiring you need will be at the amp with the exception of power. You can grab signal as well as the remote turn-on off the amp really easily.
Old Apr 16, 2010 | 07:22 PM
soulific's Avatar
soulific
I say when you do this ditch the rear speakers. GO with 6.5 in front, and replace the stock sub.
Youll get better sound staging. Im planning on doing this. I plan on ditching the stock headunit, stock amp and speakers.
Go with after market headunit, amps, and new 6.5 in the front.
Old Apr 16, 2010 | 08:47 PM
kpkim01's Avatar
kpkim01
So when wiring my new subs. Can I cut the old signal wire from the old stock amp out and connect those to the loc to gain signal? I'm still a noob at stereos so sorry if I asked any obvious questions
Old Apr 16, 2010 | 10:23 PM
dieverse's Avatar
dieverse
DGIKULJOT
May 5, 2013 11:10 AM
tubsytmac
Sep 4, 2009 03:29 AM
Vortes
Sep 5, 2008 10:16 AM
RA092423
Sep 26, 2006 04:18 PM
kmn5
Feb 16, 2006 09:01 PM
