Adding freon to my 92 SC400?
Old Aug 24, 2011 | 03:19 PM
xwingzero2's Avatar
xwingzero2
here ya go dude. its a pain in the *** to get the freon in lol.
Attached Thumbnails Adding freon to my 92 SC400?-img_0555.jpg   Adding freon to my 92 SC400?-img_0556.jpg   Adding freon to my 92 SC400?-img_0557.jpg
Old Aug 24, 2011 | 04:17 PM
xspsi6's Avatar
xspsi6
Originally Posted by 2jznosht
While we are at it...since these old cars used the now defunct r12, can I just do a recharge with the new stuff?
You must do a proper retrofit first.
Old Aug 24, 2011 | 06:25 PM
rcargile's Avatar
rcargile
Default Recharge with 134A?
Shops will tell you this is okay, but a R12 system will never be as efficient with R134. Also, the lube is a different base type, and a complete flush is near impossible. The seals are not compatible, either. Find some R12 and keep it in there as long as you can.
Old Aug 25, 2011 | 07:21 AM
kenny b's Avatar
kenny b
thanks for the pics but the 92s were not located on the firewall. im told they are on the compressor. also u can buy r12a in canada- works on r12 system-$16 a bottle-no licence required to buy or use.
Old Aug 25, 2011 | 02:37 PM
xwingzero2's Avatar
xwingzero2
Sorry i didnt help at all. But good news is that you found out where it was.
Old Aug 25, 2011 | 04:52 PM
2jznosht's Avatar
2jznosht
Anyone have a link to buy some r12?
Old Aug 25, 2011 | 06:13 PM
kenny b's Avatar
kenny b
thanks again for the pics and info guys- as it turns out its not my freon- I'm told in need and expansion valve and receiver dryer-$450 just for parts. Might go without the air for a while.
Old Aug 25, 2011 | 08:27 PM
xwingzero2's Avatar
xwingzero2
screw the air dude! im in texas and its 100-110 for awhile now and windows down
Old Aug 27, 2011 | 10:38 AM
kenny b's Avatar
kenny b
If U can handle it down there i should be able to up here
thanks again
Old Aug 27, 2011 | 08:38 PM
Asha'man's Avatar
Asha'man
If it's possible, you should start selling this to guys in the states. There are a million kinds of older enthusiast cars with R12 systems who would jump at that opportunity. You could make a killing, assuming you could get it across the border without legal issues or impounds or whatever.
Old Aug 27, 2011 | 09:17 PM
chaacmool1's Avatar
chaacmool1
Default my old compressor on my sc 400 1992
hi kenny b the line low a/c compressor is on the compressor this is one picture http://i725.photobucket.com/albums/w...Picture007.jpg
Old Aug 27, 2011 | 09:39 PM
chaacmool1's Avatar
chaacmool1
<a href="http://s725.photobucket.com/albums/ww256/chaacmool_photos/?action=view&amp;current=Picture004-6.jpg" target="_blank"><img src="http://i725.photobucket.com/albums/ww256/chaacmool_photos/Picture004-6.jpg" border="0" alt="Photobucket"></a>
hi kenny this pics is my new compressor I have the same problem my old compressor of 92 in my sc400 had a leak in the same compressor
http://i725.photobucket.com/albums/w...cture004-6.jpg
Old Aug 29, 2011 | 06:52 AM
kenny b's Avatar
kenny b
The R12a is everywhere up here. You can buy a can for $16 bucks or the whole kit ( 2 cans, the hose with guage and an adaptor to go on the unit for $54) I don't understand why it's not in the States. It indicates that it envro. friendly and I can't see the Canadian Gov. allowing it if it was like the old stuff. I'll get the name of it for yea. Maybe they have a web sight.
KB
Old May 21, 2017 | 08:15 PM
pishta's Avatar
pishta
Get yourself a side tapper with a 1/2 ACME fitting and tap into some dust-off cans. Its the same stuff as R-134 for about .15 an oz. R12a (RedTek) is not R-12. Its just Propane (R290) and Butane (R600) both are non-ozone depleting. Also R-12 compressors and systems that use Viton seals are not R-134 safe. I use torch propane all the time (R290 is pure propane, $$$ Reefer truck refrigerant) on a slow leak system cause I was sick of paying $26 a bottle for R134 here in Cal. Cut the R134 end off a filler bottle (cut with gauge) and splice it to a propane torch head. itll charge teh system enough to get compressor moving and it will cool too. yoo can use it to find leaks too, just use its pressure to find bubbles when you spray joints with soapy water. Believe it or not its hardly flammable even with a major leak because there is really not alot in there. When was the last time you had a live flame in your car next to am A/C fitting? R-134 is just as flammable (as in its not in this application). R134 is somewhat controlled here, but those dust-off cans contain the same stuff and there are $3 for 14oz here.
Old May 27, 2017 | 03:33 PM
dicer's Avatar
dicer
Ozone ? Yeah like every thing else .................
https://envronozone.com/science/ozone_science.htm
eyecon7
Mar 4, 2017 08:01 PM
Mandana76
Aug 6, 2013 12:58 AM
Bertman
Jun 27, 2013 08:10 PM
drjeckle
Jun 3, 2009 09:24 PM
Enippy
Maintenance
Jul 4, 2003 11:15 AM
