Does your engine temperature ever fluctuate slightly?
Old Nov 17, 2009 | 07:55 PM
MarcusMIA's Avatar
MarcusMIA
Default Does your engine temperature ever fluctuate slightly?
I've noticed in my 1996 SC400 that the temperature needle is always in the dead center, but it tends to go just a little higher than the middle most of the time.
How does the temperature of your car act sometimes? Same as mine?
Old Nov 17, 2009 | 08:32 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
You don't live near large hills do you? Of course not, you live in Florida. Had you lived anywhere else in the world except Florida you'd know all cars temps change all the time.
Travel the world and gain experience in life.
Old Nov 17, 2009 | 08:47 PM
OneJay's Avatar
OneJay
With my 2jz-ge, it never moved from the middle, but with my 1jz, it stays slightly above, but then on the highway it goes to center.
Old Nov 17, 2009 | 08:49 PM
MarcusMIA's Avatar
MarcusMIA
My last car was a 1999 Honda Accord V6 and the temperature needle on that thing was ROCK SOLID. It would go up to running temperature and STAY THERE. That's just MY experience.
Old Nov 17, 2009 | 08:50 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Of course it was a v6. I could regulate the temp of a v6 with a bottle of gatorade. It also didn't have a hydraulic fan.
Old Nov 17, 2009 | 09:10 PM
MarcusMIA's Avatar
MarcusMIA
Bottle of gatorade... That's a good one. I still don't see your point. The radiator on the Honda was nowhere near the massive size that the Lexus has.
Old Nov 17, 2009 | 09:11 PM
edwinbong's Avatar
edwinbong
mine is usually in the same spot, but on hot summer days it may be a bit hotter than normal
Old Nov 17, 2009 | 09:43 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
I've never had a problem with my 97 30. With my 91 31 though it'd take at least 30 minutes to warm up, then driving along it'd drop in temp and slowly creep up just above the half mark with scary BHG afterthoughts (if you've owned a 7M you'll know what I mean lol). Turned out to be a troubled thermostat. After I had it changed it's never played up since.
Old Nov 17, 2009 | 09:44 PM
BostonSC4's Avatar
BostonSC4
mine is always in the same spot...that is a bit above the dead center. always
Old Nov 18, 2009 | 01:06 AM
titanSC's Avatar
titanSC
My 94 SC300, temp never goes above center except at A/C speed level more than 2 that also if the car is not moving.
Old Nov 18, 2009 | 10:25 AM
xbox4me62's Avatar
xbox4me62
The temp gauge on my SC4 can't seem to 1 tick mark over "C". I'm thinking I need a thermostat, at least its a cheap fix.
Old Nov 18, 2009 | 01:23 PM
soarer13oy's Avatar
soarer13oy
you sure its not your temp gauge itself?
Old Nov 18, 2009 | 01:47 PM
RedPhoenix's Avatar
RedPhoenix
Ever since I installed my aluminum radiator, my needle fluctuates a lot. Its what you get when you have a fan that is always on. When its cool outside to takes forever to warm up, then drops drastically when you move.
My fix? Install electric fans on a temperature relay so its more consistent (unless its really cold!)
Old Nov 18, 2009 | 02:59 PM
davidv433's Avatar
davidv433
mine fluctuates too, i have an electric fan that is on all the time when running. So i might go with redphoenix's fix.
Old Nov 18, 2009 | 03:59 PM
saurah's Avatar
saurah
+1 electrical fans are the way to go. Thats on my to do list.
