heater problem
Old Oct 17, 2009 | 10:36 PM
millertime's Avatar
millertime
Default heater problem
I just noticed this problem this week. my heater doesnt work "right" when driving above 1500 rpms the auto function on my 95 sc400 works perfect
when im sitting at a redlight or in a parking lot it blows cold air. like im low on coolant, so i checked it. i was about a quart or so low.
problem still exists though, a friend of mine said that it could be my water pump since it is kinda making a faint wistleing sound. but im not sure
no problems with over heating or engine temp problems
Did just get the ecu rechipped from JET chips
that did bring down the idol from 1100 to 600-800 when the ac is on
any input woudl be appriciated
thanks
Old Oct 18, 2009 | 11:14 PM
shonuff53's Avatar
shonuff53
that sounds like an odd problem, I dont have an Idea of what exactly it is.. but have a friend assist you, without cutting the climate control on let the water temp get to normal operating temperature in the car then with your hood open visually check that the heater control valve operates while your friend cuts the heat on. your looking for the little lever to move on the control valve. then make sure it stays the way it is (while your doing this make sure the doors and windows are open). if it never opens check the vacuum lines if there good its the control valve. if not then fix them. however if the valve is changing with the idle it may be an electrical problem maybe with the climate control itself or wiring.. Im not a pro in this field and this is just a suggestion so any one please correct any wrong input.
ThumperPup
20
Jan 13, 2025 09:50 PM
aeropartz
Dec 22, 2009 02:12 AM
Sid Ellner
Jun 8, 2009 02:41 PM
6spdSC4
Jan 2, 2006 02:21 PM
Baby ///M3
Dec 20, 2004 08:34 PM
